  • QBank 17 posts 108 karma points
    Aug 28, 2019 @ 09:22
    QBank
    Custom Grid editor for v7.12.0 is not working
    I follow the instruction in the https://our.umbraco.com/documentation/getting-started/backoffice/property-editors/built-in-property-editors/grid-layout/build-your-own-editor and created a grid editor.
    but once i open
    choose content type
    popup the created Grid editor not present. I tried to install already created package. but that also not showing in popup.this is happening only on umbraco 7.12.0v. work fine in umbraco 8.0.0v.
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Aug 28, 2019 @ 09:27
    Are you aware of this package for Custom Grid Editors?
    https://our.umbraco.com/packages/backoffice-extensions/doc-type-grid-editor/
    This is very useful to extend Grid and do something like your are trying to do out of the box.
    Hope that helps.
    Regards,
    Shaishav
    Aug 28, 2019 @ 09:49
    QBank
    101
    ah it is my mistake grid editor was created perfectly, but it was not added to grid layout previously existed.
    Now it works fine
