  • Paul de Quant 403 posts 1521 karma points
    Mar 18, 2016 @ 09:36
    Paul de Quant
    EnsureContext issue
    I'm trying to use the following code in a IAsyncResult:-
                var searchResults = ApplicationContext.Current.Services.ContentService.GetContentOfContentType(contentType.Id);
                var httpBase = new System.Web.HttpContextWrapper(System.Web.HttpContext.Current);
                UmbracoContext.EnsureContext(httpBase, ApplicationContext.Current, new WebSecurity(httpBase, ApplicationContext.Current), UmbracoConfig.For.UmbracoSettings(), UrlProviderResolver.Current.Providers, false);
                UmbracoHelper helper = new UmbracoHelper(UmbracoContext.Current);
                var searchResultsFiltered = searchResults.Where(x => x.Name.ToLower().Contains(searchBy.ToLower())).Select(x => new { x.Name, Path = helper.NiceUrl(x.Id) });
    However, the results always comes back as:-
    Value cannot be null. Parameter name: httpContext
    I'm not that familiar with EnsureContext, so not sure I'm using it right. Can someone clarify how this should be done please.
    Many thanks
    Paul
    Mar 18, 2016 @ 10:00
    Paul de Quant
    102
    I've managed to work out how to implement this.
    Basically I had to create a new class called ContextHelper:-
     public static class ContextHelper
        public static void EnsureUmbracoContext()
            if (UmbracoContext.Current == null)
                var dummyHttpContext = new HttpContextWrapper(new HttpContext(new SimpleWorkerRequest("blah.aspx", "", new StringWriter())));
                    dummyHttpContext,
                    new WebSecurity(dummyHttpContext, ApplicationContext.Current),
                    false);
    Then in my IAsyncResult file, I just called:-
                IContentType contentType = ApplicationContext.Current.Services.ContentTypeService.GetContentType("KnowledgebaseArticle");
                ContextHelper.EnsureUmbracoContext(); // THIS IS NEW
    For more information take a look at this link:-
    https://gist.github.com/sniffdk/7600822
    Cheers
    Paul
