I have some experience in creating API for mobile applications with Umbraco.
And I would say that Umbraco is good, it easy handled a lot of data and users.
I think it's possible create jobplanner with Umbraco, it has a lot of events and scheduled tasks out of the box.
Create web application with Umbraco as base platform
I know that Umbraco is more then a CMS and that you can extend it in many ways to fit your needs.
But are there some tutorials where they explain and show how to create a web application with Umbraco as a base platform?
I mean there will be no content output only the backend will be used.
I was thinking of creating a jobplanner in ASP.NET MVC with Entity Framework but then I think maybe Umbraco can be handy for this.
Anyone that has expirience in this?
Is it common to use Umbraco for this some sort of projects? Are there downsides?
/Michael
Hi Michael,
I have some experience in creating API for mobile applications with Umbraco. And I would say that Umbraco is good, it easy handled a lot of data and users.
https://our.umbraco.org/wiki/install-and-setup/scheduled-tasks/
https://our.umbraco.org/documentation/Reference/Events/
The main question is how to customize Umbraco backend? Are you experienced in Angular?
Cheers, Alex
Hi alex,
I have no experience with angularjs but next month I take the umbraco masterclass of extending umbraco.
But I was already taking a look at some points to see if it was possible.
So what do you do to create a API on umbraco? Is it like some packages you can install like mercello? Is that the way to go or... ?
/Michael
Hi Michael,
Try to use UmbracoApiController:
https://our.umbraco.org/documentation/reference/routing/webapi/
You don't need any packages, just create usual MVC Controller and inherit it from UmbracoApiController.
Thanks, Alex
Alex,
What I mean was if the package like mercello is an example of building an api on umbraco.
So it has its own section in the backend with is controlled by a custom api controller.
/Michael
hi,
Sorry to barge.
I have a problem in changing direction. It remains the same direction for a time and then change
