  • Damon 217 posts 288 karma points
    Apr 04, 2016 @ 10:24
    Damon
    Question on how Umbraco routing works - /pagename.aspx goes to /pagename
    if you have a page that exists called "pagename"
    and you type in the url /pagename.aspx
    Then it redirects to /pagename
    Why is this? What is special about .aspx. Is this an Umbraco thing or something to do with the way IIS is set up?
    Thanks a lot for any info!
    Apr 04, 2016 @ 10:45
    Dennis Aaen
    Hi Damon,
    Try to see this documentation in the webconfig. https://our.umbraco.org/documentation/Reference/Config/webconfig/
    Search for the umbracoUseDirectoryUrls, if the value is set to true, then I will strips the .aspx from the urls.
    Hope this helps,
    /Dennis
    Apr 06, 2016 @ 12:15
    Damon
    Thank you Dennis,
    that helps a lot!
