  • Gonzalo Matias Borghi 10 posts 92 karma points
    Apr 05, 2016 @ 15:58
    Issue with custom SurfaceController
    First of all, I want to clarify that I'm just learning ASP MVC and Umbraco :). There may be very novice mistakes. I'm trying to make a system of interviews. Searching the Internet, I found an example I changed my taste. I created an empty project for testing, and this is all I have.
    Umbraco admin
    DocumentTypes
        Answer  // -->  Without template (for the moment) - No have properties (for the moment)
        Poll    // -->  Without template (for the moment) - No have properties (for the moment) - Have many "Answer" child and "Active" bool property
        Polls   // -->  Without template (for the moment) - No have properties (for the moment) - Have many "Poll" child
    PartialView
        Polls
    Umbraco content
    In Visual Studio
    Umbraco CMS (NuGet) 7.4.2
    Controllers
        PollController
    Models
        PollViewModel
        Answer
    SurfaceController
    namespace Polls.Controllers
        public class PollsController : SurfaceController
            [HttpPost]
            public ActionResult Submit(PollViewModel model)
                // Do something...
                return RedirectToCurrentUmbracoPage();
            public ActionResult Index()
                var testPage = Umbraco.Content(CurrentPage.Id);
                var questions = new List<PollViewModel>();
                foreach (var currentPoll in testPage.Where("Active"))
                    questions.Add(new PollViewModel { ID = currentPoll.ID, Title = currentPoll.Name.ToString(), Answers = AnswerList(currentPoll.ID) });
                return PartialView("~/Views/Polls.cshtml", questions);
            private List<Answer> AnswerList(int myQuestionID)
                var questionPage = Umbraco.Content(myQuestionID);
                var answers = new List<Answer>();
                foreach (var currentAnswer in questionPage.Children)
                    answers.Add(new Answer { ID = currentAnswer.ID, Text = currentAnswer.Name.ToString() });
                return answers;
    Model
    namespace Polls.Models
        public class Answer
            public int ID { get; set; }
            public string Text { get; set; } // --> No use for now
        public class PollViewModel
            public string Title { get; set; } // --> No use for now
            public List<Answer> Answers { get; set; }
    PartialView "Polls"
    @model IEnumerable<Polls.Models.PollViewModel>
    <div>
        @using (Html.BeginUmbracoForm<Polls.Controllers.PollsController>("Submit"))
            foreach (var item in Model)
                <div>
                    @Html.Hidden(item.ID.ToString())
                    <p>
                        <strong>@item.Title</strong>
                    </p>
                foreach (var answerItem in item.Answers)
                    <div>
                        @Html.RadioButton(item.Title, answerItem.ID, new { @id = answerItem.ID })
                        @Html.Label(answerItem.Text, new { @for = answerItem.ID })
            <div>
                <button type="submit">Send...</button>
    Error (When I try to compile the solution)
    Second question
    How do I filter children by custom bool property? "Poll" DocumentType have a "Active" bool property.
    This is correct?
    foreach (var currentPoll in testPage.Where("Active")) { ... }
    THX!!!!
    Apr 06, 2016 @ 12:50
    I fixed the problem, conflict was giving the name of the solution, but now have a new problem. It is very common, but can not find the solution.
  • Paul Sørensen 304 posts 650 karma points
    Apr 15, 2016 @ 21:43
    Paul Sørensen
    Quick fix for this is to upgrade to 7.4.3. Had a similar problem with RenderModel
    /Paul S
  • VanDred 6 posts 77 karma points
    Apr 15, 2016 @ 15:27
