  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Apr 15, 2016 @ 13:36
    Chris Houston
    Passing parameters to AngularJS when opening a view using the MenuItem LaunchDialogView
    Hi All,
    I am using a custom Tree in the Umbraco back office and one of my right click context MenuItem items should use the LaunchDialogView method to display a dialogs.
    The following code seems to render the dialog view, but I can't seem to access the parameter being passed in the URL. I am also not sure if this is the "right" way pass data from the tree controller to the dialog?
    MenuItem.LaunchDialogView(string.Format("{0}?id={1}", urlHelper.Content("~/App_Plugins/MyApp/backoffice/MyTree/approveAll.html"), id), "Approve All");
    Best regards,
    Chris
    Apr 15, 2016 @ 15:05
    Chris Houston
    4
    Thanks to Ben Howarth for pointing me in the right direction via a Skype chat.
    For anyone else who wants to know the answer, you need to use the following:
    In the TreeController:
    MenuItem.AdditionalData.Add("countryId",id);
    MenuItem.AdditionalData.Add("countryName", "France");
    And in the view AngularJS controller:
    var dialogOptions = $scope.dialogOptions;
    var metaData = dialogOptions.currentAction.metaData;
    $scope.countryId = metaData.countryId;
    $scope.countryName = metaData.countryName;
    Chris
