How do I get around the cross domain problem using the umbraco Web API using POST
Hi Guys, really struggling on this one. Has anyone managed to get around the cross domain problem using the post method on the UmbracoApiController.
I feel I've exhausted all efforts to try and find a solution, I even set up a new web api solution with in my umbraco project. I managed to get the cross domain problem solved in the web api solution however when I reference the umbraco solution into the web api solution I have conflicting issues. When I fixed one error, it led to another error and so on.
It just really frustrating that I have a umbraco solution and all my api methods written accessing the form, content and media services, and it works fantastic. I've even written the jquery code to post and get the data (within the same domain) and it works.
The problem just occurs when I try to post from a different URL (cross domain problem (aka CORS)).
I know I've rambled on, but I've spent nearly two days looking at this problem and the only solution I can see is avoid POST methods.
To get around this issue, I normally install the Microsoft.AspNet.WebApi.Cors NuGet package.
Once installed, you will need to configure it in your App_Start\WebApiConfig.cs with the line
config.EnableCors();
Once complete, all that remains is to mark your API controller classes with the following attribute
[EnableCors("*", "*", "*")]
This will allow all methods in the controller and all HTTP verbs. You can replace the wildcards with specific details if desired, and you can also apply this attribute at the method level instead of class level.
using System.Web.Http;
using System.Web.Http.Cors;
namespace Website
public static class WebApiConfig
public static void Register(HttpConfiguration config)
var corsAttr = new EnableCorsAttribute("*", "*", "*");
config.EnableCors(corsAttr);
Add a class that inherit from UmbracoApplication and override OnApplicationStarting and register your WebApiConfig:
using System;
using Umbraco.Web;
namespace Website.EventHandlers
public class WebApplication : UmbracoApplication
protected override void OnApplicationStarting(object sender, EventArgs e)
base.OnApplicationStarting(sender, e);
GlobalConfiguration.Configure(WebApiConfig.Register);
Change Global.asax so it inherits from the class we just created:
I just tried following you instructions, but after installing 'Microsoft.AspNet.Cors.5.2.3' through NuGet, I can't access 'System.Web.Http.Cors' only 'System.Web.Cors'
I got it working, I can't thank you enough, your a super star :) :).
I had to install 'Microsoft.AspNet.WebApi.Cors'
The funny thing is, yesterday I'd already installed this package and it caused my solution to break due to the changes in the web.config.
So, this is what worked for me, I installed 'Microsoft.AspNet.Cors' 5.2.3 first, this didn't work, I uninstalled it and installed 'Microsoft.AspNet.WebApi.Cors' 5.2.3 and it worked, then followed the instructions from Casper above.
Also remember to remove any reference to cross origin stuff in the web.config file (e.g. add name="Access-Control-Allow-Methods" value="GET, PUT, POST, DELETE, HEAD" )
Once again, thank you so much to everyone. Now I can crack on with my project.
Step 2: Create a composer somewhere in your project, I opted to create a Composers directory.
Step 3: Add the following
using Umbraco.Core;
using Umbraco.Core.Composing;
namespace Your.Web.Composers
[RuntimeLevel(MinLevel = RuntimeLevel.Boot)]
public class CorsComposer : IUserComposer
GlobalConfiguration.Configure(Register);
Has this worked for anyone else? I've just attempted this in 8.1.3 and I receive CORS preflight failures.
....from origin 'http://umbcore.local' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
Any help on this would be really appreciated.
Sorry for going on, Darren
It sounds like you need to add a response header that allow cross domain access to the resource:
or
If you want to set it up globally this can be done in application.config or web.config:
Else you can add it from within the method that you need to allow cross domain access to.
Hi Casper,
I've already added the following into my web.config file and its made no difference:
I some how have to install and enable CORS on my umbraco 7 solution
Darren
Hi Darren,
Can you share the javascript code snippet, that you're using to make the POST? :-)
Thanks!
Hi, I'm building an web app using Ionic which uses Angularjs:
Also, this is the Get method I'm using and this works:
Hi Darren,
Hope this helps.
Hywel
Hi Hywel,
Thanks, but if I was running a standard .net web api 2 solution, this wouldn't be a problem, the instructions above that you give will work f ine.
However within my umbraco 7 solution, I have no App_start folder or WebApiConfig.cs file.
I've also tried installing CORS into my umbraco solution and it updated my web.config file which cause the solution to fail.
I know what the problem is (cross domain aka CORS), but I just don't know how to fix it within my umbraco solution using the UmbracoApiController.
Thanks again
Darren
Checkout: https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/63841-Web-API-2-and-cross-origin-resource-sharing-CORS
Hi Darren,
Did you try out the approach in the link? I got it to work:
Create App_Start\WebApiConfig.cs and add:
This works for me :)
What Global.asax is that? Mine doesn't look like that at all.
Hi Andreas,
What does yours look like?
Out of the box it should just contain this:
<%@ Application Inherits="Umbraco.Web.UmbracoApplication" Language="C#" %>Dammit, i was looking in the wrong place...Sorry to disturb ;)
No problem :)
Hi Casper,
Have I installed the wrong package?
Darren
Hi Casper,
Darren
I was a bit to fast, it was the Microsoft.Aspnet.WebApi.Cors i installed. Glad you got i up and running :)
I made the same adjustments but I get following error:
The type Website.EventHandlers.WebApplication could not be found. Any help?
I moved the classes to the folder APP_Code
If anyone is looking to get this working in v8, I found an easy solution using the new application composers:
composersomewhere in your project, I opted to create aComposersdirectory.Step 3: Add the following
Hope that helps!
Or you can go without create Composer and enable CORS on
WebApiConfigregistration.Microsoft.AspNet.Corspackageenable CORS in your
WebApiConfigbefore register routs (it is urgent)public static class WebApiConfig { public static void Register(HttpConfiguration config) { config.EnableCors(new EnableCorsAttribute("{allowed origins}", "", ""));
add headers to web.config
customHeaderssection<remove name="Access-Control-Allow-Origin" /><add name="Access-Control-Allow-Origin" value="{allowed origin}" /><remove name="Access-Control-Allow-Credentials" /><add name="Access-Control-Allow-Credentials" value="true" />Thanks for sharing but not working
I ended up managing CORS via Azure.
