I want to add the list of servers to the Appsettings.config so I can use the the slot only feature in Azure.
Ie I don't necessarily want the pre-production slots to getting the update from the live servers.
Is there a way, to change the servers list in the UmbracoSettings.Config via API? Or any other suggestions to achieve this
I realised this was unrequired. I was thinking pre 7.3 when the servers where required to be specified.
But it isn't required now in the new load balancing
Using Azure Deployment slots and Changing the Distributed servers on swap
