  • Bezmundo 48 posts 139 karma points
    May 12, 2016 @ 16:47
    Bezmundo
    Using Related Links in a custom as Umbraco macro for grid
    I've tried to port the related link property type to a custom macro parameter. The template loads once selected in the grid but it cannot read the max value stored in the property type.
    Any ideas
       alias: "Demo.CTALink",
            isParameterEditor: true,
            editor: {
            view: "relatedlinks"
    I've tried calling the umbraco.controllers.js through the javascript and assigning a prevalue for the max value but still no luck.
    Heres the output: Console error shown
  • Paul de Quant 403 posts 1519 karma points
    Aug 25, 2017 @ 16:24
    Paul de Quant
    Did you manage to get this working?
  • Marc Goodson 1895 posts 12558 karma points MVP 7x c-trib
    Aug 27, 2017 @ 21:28
    Marc Goodson
    Hi Paul
    The trick is to supply a defaultConfig option in the package manifest file;
    https://our.umbraco.org/Documentation/Extending/Macro-Parameter-Editors/
    eg
            editor: {
    defaultConfig: {
       maxValue: 4
    regards
    Marc
    Aug 29, 2017 @ 09:00
    Paul de Quant
    Hi Marc,
    Thanks for this, it works but the only downside is that it doesn't show all the options. It seems to crop off the new window and the add button.
    Is there a way to show everything?
    Paul
    Aug 29, 2017 @ 22:44
    Marc Goodson
    Hi Paul
    I see what you mean!
    The RJP.MultiUrl picker is probably better suited as a macro parameter:
    https://our.umbraco.org/projects/backoffice-extensions/multi-url-picker/
    but if you were set on using relatedlinks you could add a stylesheet to your package manifest file:
        propertyEditors: [
            alias: "RelatedLinksTest",
            name: "Related Links Test",
            editor: {
            view: "relatedlinks",
            hideLabel:false
            isParameterEditor:true,
            defaultConfig: {
                  maxValue: 4
          css: [
    '~/App_Plugins/RelatedLinksMacroParameter/relatedLinksMacroParameter.css',
    and then apply some styling rules for the situation when the related links view appears in a macro overlay eg:
    .umb-overlay-right .umb-relatedlinks {
    overflow-x:auto;
    would add a scroll bar..
    but you may be able to style it better, basically it's a table!
    I would tend to use the RJP multi url picker here, as whilst this is a third party plugin, it appears to behave more closely to the core content pickers than the relatedlinks user interface and it fits!
