How to use models builder in controller, in other words, how to get strongly typed model within controller
Hi to all,
I want to use Umbraco models builder in the latest version 7.4.3 and I can't find any post on Google or within GitHub documentation how to "inject" my strongly typed model from models builder into a controller. I don't want to use content models directly into views. It would be good to have this example in the official documentation, instead of just saying that we can use strongly typed models everywhere, including controllers.
If your working with controllers in visual studio, rather than just in views; you can switch ModelsBuilder settings in the web.config to 'AppData' mode: (instead of PureLive)
Now when you generate your models, you will find in the AppData folder a 'Models folder'
with generated c# classes representing each document type:
Include this Models folder in your visual studio project, and you can begin to use the strongly built models inside your controllers:
Each model has a contructor that takes an IPublishedContent so you could create a hijacked controller like so...
public class DocTypeAliasController : RenderMvcController
public override ActionResult Index(RenderModel model)
var viewModel = new MyGeneratedDocTypeModel(model.Content);
return CurrentTemplate(viewmodel);
but in reality you'd probably created your own custom model that inherits from the generated model to add further custom properties that you would populate in your hijacked controller...
Thank you very much for your detailed explanation, everything is clear now!
I think this needs to be included in the official GitHub documentation, for sure.
Hi to all,
I appreciate.
Cheers, Bojan
Hi Bojan
regards
Marc
Hi Marc,
Thank you very much for your detailed explanation, everything is clear now! I think this needs to be included in the official GitHub documentation, for sure.
Happy coding, Bojan
I'm with you on that one.
I found out the constructor taking a Model.Content by Intellisense!
