  • Tim C 161 posts 528 karma points
    May 27, 2016 @ 09:48
    Tim C
    Visual Studio create project from existing code
    I am using Umbraco from a hosting supplier, but want to try to write a web service and therefore build a dll.
    So I downloaded all the folders to my local machine and fired up Visual Studio 2015 Community Edition
    I tried to create a project (as the hosted system doesn't include a project or solution file) from existing code.
    From the menu, I chose
    File
    Project from existing code
    choose C#
    and selected my folder
    It then asked for name and output type : however, the only output types available are
    • Console Application
    • Windows Application
    • Class Library
    There is no option for 'Web Site'
    Has anyone come across this before? Do I need to change some settings? I assume this must be possible!
  • Bijesh Tank 192 posts 420 karma points
    May 27, 2016 @ 10:52
    Bijesh Tank
    101
    Hi Tim,
    I believe you have to open it as a website first in your case.
    File -> Open -> Web Site
    Then you can save a solution: File -> Save MySite.sln
    Then you can create a new project in that solution.
    B.
    May 27, 2016 @ 13:29
    Tim C
    It seems this version won't save solutions, only projects!
    May 27, 2016 @ 13:46
    Tim C
    Sorry, it does, but implcitly. This has worked!
    May 27, 2016 @ 14:13
    Bijesh Tank
    I was in the middle of a reply back to you till I saw your update!
    Glad it worked :)
