  • Jonathan Ben Avraham 43 posts 216 karma points
    Jun 08, 2016 @ 12:28
    Trying to grab and export IContent to XML using Linq and Umbraco ContentService
    Hi All,
    I'll start by explaining what I would like to achieve:
    I would like to grab content from umbraco (Blog posts and comments) and store them in an XML which looks like this:
    Please note: BlogPosts and Comments are separate DocumentTypes.
    <BlogPosts>
      <Blog>
        <Title>This is a blog post</Title>
        <BodyText>&lt;p&gt;This is a second blog post's content&lt;/p&gt;</BodyText>
        <PublishDate>06/06/2016 00:00:00</PublishDate>
        <Author>0</Author>
        <Image>1117</Image>
        <Comments>
            <Author>John Smith</Author>
            <Comment>This is an awesome comment</Comment>
        </Comments>
      </Blog>
    </BlogPosts>
    This is what I have got so far:
        namespace UmbracoBlogsExportPackage.App_Code
        public class ExportAllBlogsController : UmbracoAuthorizedApiController
            [System.Web.Http.AcceptVerbs("GET", "POST")]
            public void ExportAll()
                List<BlogPosts> BlogPostList = new List<BlogPosts>();
                BlogPostList = getPostList();
                //List<BlogComment> blogCommentList = new List<BlogComment>();
                //blogCommentList = getCommentList();
                string attachment = "attachment; filename= ExpBlogPosts.xml;";
                HttpContext.Current.Response.Clear();
                HttpContext.Current.Response.ClearHeaders();
                HttpContext.Current.Response.ClearContent();
                HttpContext.Current.Response.AddHeader("Content-Disposition", attachment);
                HttpContext.Current.Response.ContentType = "text/xml";
                HttpContext.Current.Response.AddHeader("Pragma", "public");
                HttpContext.Current.Response.CacheControl = "private";
                XDocument xdoc = new XDocument();
                    foreach (var index in BlogPostList)
                            var xEle = new XElement("BlogPosts",
                                from blog in BlogPostList
                                where blog.Title != null
                                where blog.BodyText != null
                                where blog.Author != null
                                where blog.Image != null
                                where blog.PublishDate != null
                                select new XElement("Blog",
                                                new XElement("Title", blog.Title),
                                                new XElement("BodyText", blog.BodyText),
                                                new XElement("PublishDate", blog.PublishDate),
                                                new XElement("Author", blog.Author),
                                                new XElement("Image", blog.Image),
                                                new XElement("Comments", blog.Comments)
                                                //from comment in blogCommentList
                                                //select new XElement("Comments",
                                                //    new XElement("Author", comment.Author),
                                                //    new XElement("Comment", comment.Comment)
                           xdoc.Add(xEle);
                           HttpContext.Current.Response.Write(xdoc);
                           HttpContext.Current.Response.End();
                           HttpContext.Current.Response.Flush();
            public List<BlogPosts> getPostList()
                var contentType = UmbracoContext.Current.Application.Services.ContentTypeService
                    .GetContentType("umbNewsItem");
                var contentService = UmbracoContext.Current.Application.Services.ContentService;
                var nodes = contentService.GetContentOfContentType(contentType.Id);
                return nodes.Select(node => new BlogPosts()
                    Title = node.GetValue("title").ToNullSafeString(),
                    BodyText = node.GetValue("bodyText").ToNullSafeString(),
                    PublishDate = node.GetValue("publishDate").ToNullSafeString(),
                    Author = node.GetValue("author").ToNullSafeString(),
                    Image = node.GetValue("image").ToNullSafeString(),
                    Comments = getCommentList(node.Id)
                }).ToList();
            public List<BlogComment> getCommentList(int nodeid)
                var contentType = UmbracoContext.Current.Application.Services.ContentTypeService.GetContentType("comments");
                var x = contentService.GetChildren(nodeid);
                return nodes.Select(node => new BlogComment()
                        Comment = node.GetValue("comment").ToNullSafeString()
                    }).ToList();
    Currently I get this output:
    <BlogPosts>
      <Blog>
        <Title>Random Blog Post</Title>
        <BodyText>&lt;p&gt;This is a new random blog post's content&lt;/p&gt;</BodyText>
        <PublishDate>10/06/2016 00:00:00</PublishDate>
        <Author>0</Author>
        <Image>1114</Image>
        <Comments>uBlogsyUmbracoExport.Models.BlogCommentuBlogsyUmbracoExport.Models.BlogCommentuBlogsyUmbracoExport.Models.BlogCommentuBlogsyUmbracoExport.Models.BlogCommentuBlogsyUmbracoExport.Models.BlogComment</Comments>
      </Blog>
      <Blog>
        <Title>This is a second blog post</Title>
        <Author>0</Author>
        <Image>1117</Image>
      </Blog>
    </BlogPosts>
    That's the first issue. The second is the fact that I have more than these two posts. I actually have 5 posts, yet only two are being pulled through.
    Jun 14, 2016 @ 14:43
    Here was my solution:
    using uBlogsyUmbracoExport.Models;
    using System;
    using System.IO;
    using System.Linq;
    using System.Net;
    using System.Web;
    using System.Web.Mvc;
    using System.Text;
    using System.Data;
    using System.Data.SqlClient;
    using Umbraco.Core.Persistence;
    using Umbraco.Web;
    using Umbraco.Web.WebApi;
    using Umbraco.Core;
    using Umbraco.Core.Models;
    using Umbraco.Core.Services;
    using umbraco.NodeFactory;
    using AutoMapper.Internal;
    using System.Xml.Linq;
    using System.Xml.Serialization;
    using System.Xml.XPath;
                                    from comment in blog.Comments
                xdoc.Add(xEle);
                }).ToList();
            public List<BlogComment> getCommentList(int blogPostId)
                var comments = UmbracoContext.Current.Application.Services.ContentService.GetById(blogPostId).Descendants().Where(n=>n.ContentType.Name == "comment");
                return comments.Select(node => new BlogComment()
                    }).ToList();
