Topic author was deleted
Jun 16, 2016 @ 09:15
Examine, Lucene, escaping chars and wildchar issue
Got a small issue I’m trying to solve here, got a search running with examine and trying to search for words that contain a - (so that needs to be escaped) if I combine that with a wildcard char I get no results, anyone who can explain that? So this works (returns results for the word fit-o-meter)
Well contents:fit-o-mete* is part of my generated criteria, and I'm just using the dashboard examine control to execute a raw lucene query against the index...
Ignore that last comment. In luke find a document that acutally has that term then look at the contents field in luke what do you see?
I think it may be something todo with analyser not tokenising due to the - so for first query its exact match but for second query its going to try partial match on tokens but those individual tokens do not exist.
contents:fit\-o\-meterbut this doesn’t return any results
contents:fit\-o\-mete*Tim,
Whats the generated query? So do a criteria.tostring
Regards
Ismial
Comment author was deleted
Tim,
Try the query in luke java version and then get a breakdown via explain button see what its doing.
Regards
Ismail
Ok thanks Ismail, will give that a go :)
Tim,
Regards
Ismail
Tim,
Bit more digging see http://stackoverflow.com/questions/2600940/hyphens-in-lucene
Thanks!
