[TableName("udfUnionMunicipalities")]
[PrimaryKey("id", autoIncrement = false)]
[ExplicitColumns]
public class UnionMunicipality
/// <summary>
/// OfficialCode
/// </summary>
[Column("id")]
[PrimaryKeyColumn(AutoIncrement = false)]
public string Id { get; set; }
[Column("name")]
public string Name { get; set; }
/// <summary>
/// Company Category
/// </summary>
[TableName("udfUnionCategories")]
[ExplicitColumns]
public class UnionCategory
[Column("id")]
public int Id { get; set; }
[Column("name")]
/// <summary>
/// Company
/// </summary>
[TableName("udfUnions")]
[ExplicitColumns]
public class Union
[Column("id")]
[Column("name")]
[Column("categoryId")]
[ForeignKey(typeof(UnionCategory))]
public int CategoryId { get; set; }
[ForeignKey(typeof(UnionMunicipality))]
[Column("municipalityId")]
public string MunicipalityId { get; set; }
[ResultColumn]
public UnionMunicipality Municipality { get; set; }
[ResultColumn]
public UnionCategory Category { get; set; }
Then i used the following query to join Category and Municipality on Union table
var sql = new Sql()
.Select("udfUnions.*, udfUnionMunicipalities.*, udfUnionCategories.*")
.From<Union>(dbContext.SqlSyntax);
sql.InnerJoin<UnionMunicipality>(dbContext.SqlSyntax)
.On<Union, UnionMunicipality>(dbContext.SqlSyntax, u => u.CategoryId, c => c.Id)
.InnerJoin<UnionCategory>(dbContext.SqlSyntax)
.On<Union, UnionCategory>(dbContext.SqlSyntax, u => u.CategoryId, c => c.Id);
LogHelper.Info<UnionsRepository>(() => sql.SQL);
return db.Fetch<Union, UnionMunicipality, UnionCategory, Union>((u, m, c) => {
u.Municipality = m;
u.Category = c;
return u;
}, sql);
Outputs following sql:
SELECT udfUnions.*, udfUnionMunicipalities.*, udfUnionCategories.*
FROM [udfUnions]
LEFT JOIN [udfUnionMunicipalities]
ON [udfUnions].[municipalityId] = [udfUnionMunicipalities].[id]
LEFT JOIN [udfUnionCategories]
ON [udfUnions].[categoryId] = [udfUnionCategories].[id]
I also tried writing the SQL manually like so:
SELECT *
FROM udfUnions
INNER JOIN udfUnionMunicipalities
ON udfUnions.MunicipalityId = udfMunicipalties.Id
INNER JOIN udfUnionCategories
ON udfUnions.CategoryId = udfUnionCategories.Id
Like the heading says, i also tried using LEFT JOIN
What did you expect to happen?
That the tables would be mapped to correct result columns
What actually happened?
I know it not much, but this is what the log shows:
How to use InnerJoin or LeftJoin with POCO
What did you do?
I've created the following models:
What did you expect to happen? That the tables would be mapped to correct result columns
What actually happened? I know it not much, but this is what the log shows:
Any help would be appreciated!
