  • Libin Joseph 9 posts 31 karma points
    Jul 27, 2016 @ 03:39
    Libin Joseph
    URL when using Umbraco as a Backend
    What is the best way to manage URL’s when using Umbraco just for the backend, (ie: Umbraco for content managing, and the website UI is a normal MVC application, and the contents are sent via UmbracoAPI controllers).
    To be precise , what is the best approach for handling URL's for breadcrumbs and search feature
  • Alex Skrypnyk 6176 posts 24187 karma points MVP 8x admin c-trib
    Jul 31, 2016 @ 22:26
    Alex Skrypnyk
    Hi Libin,
    As I understand you have these variants:
    1) Handle urls with route table manually like here - https://msdn.microsoft.com/en-us/library/cc668201.aspx#addingroutestoanmvc_application
    or - http://stephenwalther.com/archive/2015/02/07/asp-net-5-deep-dive-routing
    If you are using MVC 5 or 6 there are great possibility to use Attribute-Based Routing
    2) Install another Umbraco for handling pages and urls )
    3) Write custom helpers for working with URLs and store urls in database.
    Alex
