I am c;reating multilingual site using Vorto.
I have already created a Bootstrap Navigation Menu
Using Vorto I have created a property pageTitle and wanted to assign the value of pageTitle onto Navigation Menu as per the pages available.
As far as now, my code is ...
@using Our.Umbraco.Vorto.Extensions
<ul class="nav navbar-nav">
var maxLevelForNav = 4;
var home = CurrentPage.AncestorsOrSelf(1).First();
@RenderNavForNode(home, 1)
foreach (var page in home.Children.Where("NodeTypeAlias != \"register\"").Where("Visible"))
@RenderNavForNode(page, maxLevelForNav);
</ul>
@helper RenderNavForNode(dynamic page, int maxLevel)
var current = CurrentPage.Id == page.Id ? "active" : null;
if (page.Children.Where("Visible").Any() && page.Level == 2)
@:<li class="dropdown @current"><a href="@page.Url" class="dropdown-toggle disabled" data-toggle="dropdown">@page.Name<span class="caret"></span></a>
else if (page.Children.Where("Visible").Any() && page.Level > 2)
@:<li class="dropdown-submenu @current"><a class="@current" href="@page.Url">@page.Name</a>
else
@:<li><a class="@current" href="@page.Url">@page.Name</a></li>
if (page.Children.Where("Visible").Any() && page.Level < maxLevel)
<ul class="dropdown-menu" role="menu">
@foreach (var subPage in page.Children.Where("Visible"))
@RenderNavForNode(subPage, maxLevel)
</ul>
Instead of @page.Name, I have used @Model.Content.GetVortoValue("pageTitle") but that returns only the pageTitle of the current page not other pages which is supposed to display.
There are several ways to work with Umbraco nodes in templates, one is to use the dynamic approach, as you have here, eg using CurrentPage and pulling back your list of children as dynamic page objects
and another is a
a more 'strongly typed' approach using 'IPublishedContent' , ie using @Model.Content instead of CurrentPage to access and navigate the Umbraco content tree.
GetVortoValue is an extension to IPublishedContent, and so if you try to use it from your dynamic object, eg
page.GetVortoValue("pageTitle") it won't work.
You could either cast the dynamic object into IPublishedContent in your foreach loop
or maybe if your site is working alot with Vorto, you might consider using the IPublishedContent approach throughout your site, when retrieving nodes eg:
var home = Model.Content.AncestorsOrSelf(1).FirstOrDefault();
foreach (var page in home.Children().Where(f=>f.IsVisible() && f.DocumentTypeAlias == "register"))
<li>@page.GetVortoValue("pageTitle")</li>
Thanks very much for your valuable suggestion.
But, can you please provide the whole code if I intend to convert the above code in IPublishedContent approach
Bootstrap Navigation Menu using Vorto
Hello All,
I am c;reating multilingual site using Vorto. I have already created a Bootstrap Navigation Menu Using Vorto I have created a property pageTitle and wanted to assign the value of pageTitle onto Navigation Menu as per the pages available. As far as now, my code is ...
Can anyone help me in this case.
Regards.
Hi Mangirish
and another is a
eg:
Theres a great article here about the differences between dynamic and strongly typed content: http://24days.in/umbraco/2015/strongly-typed-vs-dynamic-content-access/
Hello Marc,
Very much thanks for your suggestion.
I finally casted the dynamic object into IPublishedContent in your foreach loop and got this final code.
Thanks very much for your valuable suggestion. But, can you please provide the whole code if I intend to convert the above code in IPublishedContent approach
Regards. :)
Something like this:
Thank you Marc very Much. Will try it definitely.
