I had Hosted my website built in Umbraco in IP address the website is working properly but when i am opening the admin panel IP/Umbraco it throws the error of 404 File or directory not found
Need help :(
Hi Sagar,
Are you sure that connection works fine to your site? Can you check project locally? Can you look at logs?
My entire website is working fine but the admin panel throws 404 not found :(
Are you hosting the umbraco folder?
Yes Umbraco folder is too added in it
Another silly question just in case :) Have you tried with /umbraco/login.aspx?
I guess that if you provide more info about your site like the umbraco version is going to be easier to find the issue.
Same error 404 not found
Now it shows me Like this
Umbraco Admin Panel Not found 404
Need help :(
Hi Sagar,
