public RelatedLinks RelevantLinks { get; set; }
If RelevantLinks is empty, I get this error
InvalidOperationException: {"Sequence contains no elements"}, but i want it to be empty.
What line is throwing that exception. Do you need to replace RelevantLinks.First() with RelevantLinks.FirstOrDefault()?
It's throwing the exception when I try to store it into my Ditto model. I'm not usnig First() or FirstOrDefault() yet. I haven't begun trying to pull the data, it's erroring before I can even do that.
Bums. Sounds like a Ditto issue. You might have more luck posting it on that forum.
Error on using RelatedLink with Ditto and Jeavon Property Converter
RelevantLinks.First()withRelevantLinks.FirstOrDefault()?It's throwing the exception when I try to store it into my Ditto model. I'm not usnig First() or FirstOrDefault() yet. I haven't begun trying to pull the data, it's erroring before I can even do that.
