  • Hefin Jones 39 posts 161 karma points
    Aug 11, 2016 @ 15:26
    Hefin Jones
    Custom Route, Controller and Model issue
    Hello :-)
    I'm trying to implement a "View Profile" page using a custom route, controller and model. But can't get it to work :-(
    My custom route is:
    RouteTable.Routes.MapRoute(
                    "memberProfileRoute",
                    "user/{profileURLtoCheck}",
                    new
                        Controller = "ViewProfile",
                        Action = "Index"
    My controller is:
    public class ViewProfileController : RenderMvcController
        public ViewProfileController() : this(UmbracoContext.Current) { }
        public ViewProfileController(UmbracoContext umbracoContext) : base(umbracoContext) { }
        public override ActionResult Index(RenderModel model)
            string profileURLtoCheck = Request.RequestContext.RouteData.Values["profileURLtoCheck"].ToString();
            ViewProfileViewModel profile = new ViewProfileViewModel();
            if (!String.IsNullOrEmpty(profileURLtoCheck))
                var ms = UmbracoContext.Current.Application.Services.MemberService;
                var findMember = ms.GetAllMembers().FirstOrDefault(x => x.GetValue<string>("profileURL") == profileURLtoCheck);
                if (findMember != null)
                    profile.Name = findMember.Name;
            return CurrentTemplate(profile);
    And the model is this:
    public class ViewProfileViewModel : RenderModel
        public ViewProfileViewModel() : base(UmbracoContext.Current.PublishedContentRequest.PublishedContent) { }
        public string Name { get; set; }
    This is my View:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<ViewProfileViewModel>
        Layout = "~/Views/Design.cshtml";
    <h2>@Model.Name</h2>
    When I try to navigate to the route e.g. http://www.mysite.co.uk/user/joebloggs I keep getting errors. If I inherit from RenderModel in my model as shown above I get:
    on the constructor, and if I don't inherit from RenderModel I get the following error:
    Cannot bind source type ViewProfileViewModel to model type Umbraco.Web.Models.RenderModel
    I seem to be going around in circles .... any help would be greatly appreciated.
  • Micha Somers 134 posts 597 karma points
    Aug 11, 2016 @ 15:43
    Micha Somers
    What happens if you add an IPublishedContent parameter to your constructor, like this:
        public ViewProfileViewModel(IPublishedContent content) : base(content) { }
    Aug 11, 2016 @ 15:51
    Hefin Jones
    Hi Micha,
    If I add the line of code to the Model as you suggested, I get an error in the Controller on this line:
    There is no argument given that corresponds to the required formal parameter 'content' of 'ViewProfileViewModel.ViewProfileViewModel(IPublishedContent)
    If I update the controller line to:
    ViewProfileViewModel profile = new ViewProfileViewModel(CurrentPage);
    DataTokens must contain an 'umbraco-doc-request' key with a PublishedContentRequest object
    I assume this is because /user/profilename isn't an Umbraco page?
    Aug 11, 2016 @ 16:48
    Micha Somers
    For creating an instance of your ViewProfileViewModel, I think you need to use model.Content instead of CurrentPage:
    ViewProfileViewModel profile = new ViewProfileViewModel(model.Content);
    Aug 12, 2016 @ 08:08
    Hefin Jones
    Still get an error, on that line :-( ...
    Isn't this because model.Content is null because my custom route / view isn't actually an Umbraco page?
    Aug 12, 2016 @ 09:40
    Micha Somers
    So if I understand you correctly, there is no node available to refer to.
    For this approach you need an instance of IPublishedContent, so without a node being available, a virtual node must be created/found.
    The following resources can help you further on that topic:
    http://shazwazza.com/post/custom-mvc-routes-within-the-umbraco-pipeline/
    https://stackoverflow.com/questions/35647220/how-to-create-a-virtual-node-in-umbraco
