I have a site where one of the users has moved a bunch of content to a different section in the content tree, however any time we try and publish the content we get a cannot publish because a parent is unpublished warning
If I have moved a content item surely it should no longer be in the path variable of
the value 1186 refers to an item that is no longer linked to this content...
Beyond republishing the site is there anything else I have missed?
but rebuilding the examine index won't change the umbraco.config , admittedly I have also checked the CMSContent XML table and the unwanted 1186 is in the path variable so when i rebuild i get the same problem with the cache and publishing
Umbraco.Config path issue
Rebuilding the examine index?
I'll try it though
