  • Bezmundo 48 posts 139 karma points
    Aug 30, 2016 @ 13:35
    Bezmundo
    XML Data Integrity - ContentXml won't fix
    I've been trying to use the Umbraco Api in order to access content. However when I access the API i get an error saying the XML is invalid.
    On checking the health check features in the new Umbraco it says I have two invalid entries as shown in the image below:
    Is there a quick way to find these errors as I have over 3000+ rows in the cmsContentXml table.
    Note this was originally running on Umbraco 4 before being upgraded to 7.5.2
    NOTE: What i forgot to mention is that selecting the fix button doesn't correct the issue.
  • Richard Thompson 100 posts 336 karma points
    Aug 30, 2016 @ 13:39
    Richard Thompson
    I don't know if it's the same cause I had but I had the same issue http://issues.umbraco.org/issue/U4-8911
    Aug 30, 2016 @ 13:48
    Bezmundo
    I have cleared out the recycle bin but still produces same error. Thanks for your efforts though
    Aug 30, 2016 @ 14:20
    Bezmundo
    Actually fixed this. Just manually delete all values in the cmsContentXml table and this will force it to properly generate a new valid XML
  • Damiaan 441 posts 1298 karma points MVP 5x c-trib
    Aug 30, 2016 @ 22:15
    Damiaan
    The 2 errors can be found by translating the checkContent code into SQL:
            var subQuery = new Sql()
                .Select("DISTINCT cmsContentXml.nodeId")
                .From<ContentXmlDto>(_sqlSyntax)
                .InnerJoin<DocumentDto>(_sqlSyntax)
                .On<DocumentDto, ContentXmlDto>(_sqlSyntax, left => left.NodeId, right => right.NodeId);
    Not sure what the .On() does. But pretty sure it has to do with the inner join. :)
