Umbraco 7 with Unity and Web API and Controller DI
Hi I am attempting to get Unity working with Umbraco 7.5.3 assembly: 1.0.6092.24019 alongside Web API
I have Web API working, with Unity with Umbraco installed and have an interface being resolved in a controller constructor.
The API works fine, the back office is fine but I get the following error on the home page of the site.
[ResolutionFailedException: Resolution of the dependency failed, type = "Umbraco.Web.Mvc.RenderMvcController", name = "(none)".
Exception occurred while: while resolving.
Exception is: InvalidOperationException - The type UmbracoContext does not have an accessible constructor.
I have the following MVC activator class in start up
using System.Linq;
using System.Web.Mvc;
using Microsoft.Practices.Unity.Mvc;
using System.Web.Http;
namespace UmbracoWebAPISetup.App_Start
/// <summary>Provides the bootstrapping for integrating Unity with ASP.NET MVC.</summary>
public static class UnityWebActivator
/// <summary>Integrates Unity when the application starts.</summary>
public static void Start()
var container = UnityConfig.GetConfiguredContainer();
FilterProviders.Providers.Remove(FilterProviders.Providers.OfType<FilterAttributeFilterProvider>().First());
FilterProviders.Providers.Add(new UnityFilterAttributeFilterProvider(container));
DependencyResolver.SetResolver(new UnityDependencyResolver(container));
GlobalConfiguration.Configuration.DependencyResolver = new Unity.WebApi.UnityDependencyResolver(container);
// TODO: Uncomment if you want to use PerRequestLifetimeManager
// Microsoft.Web.Infrastructure.DynamicModuleHelper.DynamicModuleUtility.RegisterModule(typeof(UnityPerRequestHttpModule));
/// <summary>Disposes the Unity container when the application is shut down.</summary>
public static void Shutdown()
container.Dispose();
and the following UnityConfig class file in start up
using System;
using Microsoft.Practices.Unity;
using Microsoft.Practices.Unity.Configuration;
using CustomServices;
using Umbraco.Web;
/// <summary>
/// Specifies the Unity configuration for the main container.
/// </summary>
public class UnityConfig
#region Unity Container
private static Lazy<IUnityContainer> container = new Lazy<IUnityContainer>(() =>
var container = new UnityContainer();
RegisterTypes(container);
return container;
/// <summary>
/// Gets the configured Unity container.
/// </summary>
public static IUnityContainer GetConfiguredContainer()
return container.Value;
#endregion
/// <summary>Registers the type mappings with the Unity container.</summary>
/// <param name="container">The unity container to configure.</param>
/// <remarks>There is no need to register concrete types such as controllers or API controllers (unless you want to
/// change the defaults), as Unity allows resolving a concrete type even if it was not previously registered.</remarks>
public static void RegisterTypes(IUnityContainer container)
// NOTE: To load from web.config uncomment the line below. Make sure to add a Microsoft.Practices.Unity.Configuration to the using statements.
// container.LoadConfiguration();
// TODO: Register your types here
// container.RegisterType<IProductRepository, ProductRepository>();
container.RegisterType<IPagesService, PagesService>();
Solution: adding the following to my UnityConfig.cs
container.RegisterType<UmbracoContext>(
new ContainerControlledLifetimeManager(),
new InjectionFactory(c => UmbracoContext.Current))
.RegisterType<RenderMvcController>(
new InjectionConstructor(new ResolvedParameter<UmbracoContext>()))
Turns out that the following line break the back office
I am unable to create any items.
I get the error: Server Error, Contact your administrator, check the logs for further information.
failed to retrieve data for empty content item type TextPage
{"Message":"An error has occurred.","ExceptionMessage":"Object reference not set to an instance of an object.","ExceptionType":"System.NullReferenceException","StackTrace":" at Umbraco.Web.Security.WebSecurity.IsAuthenticated()\r\n at Umbraco.Web.Security.WebSecurity.ValidateCurrentUser(Boolean throwExceptions)\r\n at Umbraco.Web.WebApi.UmbracoAuthorizedApiController.getUmbracoUser()\r\n at Umbraco.Web.Editors.ContentController.GetEmpty(String contentTypeAlias, Int32 parentId)\r\n at lambdamethod(Closure , Object , Object[] )\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>cDisplayClass10.9(Object instance, Object[] methodParameters)\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Controllers.ApiControllerActionInvoker.
I have Web API working, with Unity with Umbraco installed and have an interface being resolved in a controller constructor. The API works fine, the back office is fine but I get the following error on the home page of the site.
[ResolutionFailedException: Resolution of the dependency failed, type = "Umbraco.Web.Mvc.RenderMvcController", name = "(none)". Exception occurred while: while resolving. Exception is: InvalidOperationException - The type UmbracoContext does not have an accessible constructor.
Have managed to resolve this from two articles: A big thanks to: Alex G and Shannon D
Articles: Unity IOC Error
Unity IOC Upgrade
I get the error: Server Error, Contact your administrator, check the logs for further information. failed to retrieve data for empty content item type TextPage
I cannot find any error in logs relating to this
Error from Chrome Debug:
