We have a custom membership provider that we are using with umbraco, all been working fine. The custom table used by the provider has field id which is of type guid.
We recently ugraded from 7.2.8 to 7.5.3 and now in backoffice when u click a member in list view we get error 400.
They changed from using a custom UI for members to using the grid view.
Grid view uses ID which it is expecting to be int not guid. Anyone else seen this?
I then upgraded to 7.5.3. When I try to view a member and look in chrome inspector console i get:
{"Message":"The request is invalid.","MessageDetail":"The parameters dictionary contains a null entry for parameter 'key' of non-nullable type 'System.Guid' for method 'Umbraco.Web.Models.ContentEditing.MemberDisplay GetByKey(System.Guid)' in 'Umbraco.Web.Editors.MemberController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter."}
I noticed something similar with membertypes and guids when testing uSync
pre v7.5.3 (maybe pre 7.5.2) the guid values for properties inside a membertype where there but always set to zeros (0000-00000) if you build a new 7.5.3 they are set to actual guids. I suspect this might be a thing with an upgrade :-(
the hacky way to fix it that to enumerate property types inside the MemberType and set the key to a guid value (Guid.NewGuid() i think ??).
Might not be this, but that's' something i noticed with 7.5.3
You lost me there, this is for custom member table, with umbraco one there is config option use guid else it assumes id is int. However with custom membership that inherits from asp.net membership dues not set this property.
That id at the end is value of maxint. It should be the guid. If you replace the max id manually with guid then you get the member. So think there is a problem in the controller.
Custom membership issue after upgrade to 7.5.3
They changed from using a custom UI for members to using the grid view. Grid view uses ID which it is expecting to be int not guid. Anyone else seen this?
Regards
Ismail
So I just downloaded code from this article http://24days.in/umbraco/2015/extending-membership/ and source code https://github.com/pbres/24days.in.Umbraco.MembersProject
Regards
Ismail
Kevin
Kevin,
Regards
Ismail
yeah, ignore me, my brain saw Guid and member and it obviously brought back a traumatic experience :)
Kevin,
So here is the weird thing. In the gridview when you click on a member the url is
Regards
Ismail
Kevin,
https://github.com/umbraco/Umbraco-CMS/blob/5397f2c53acbdeb0805e1fe39fda938f571d295a/src/Umbraco.Web/Models/Mapping/MemberModelMapper.cs
Line 41.
Mystery solved kind of lol
Hi Ismail, just ran into this too.
Did you solve your problem, and how?
