  • Hefin Jones 39 posts 161 karma points
    Oct 19, 2016 @ 14:11
    Hefin Jones
    Prevent Deleting / Unpublish and display notification to editor
    Hello
    I'm currently trying to prevent deletion and unpublishing of certain pages and media. I've got the following code:
    private void ContentService_UnPublishing(IPublishingStrategy sender, PublishEventArgs<IContent> e)
        foreach (var item in e.PublishedEntities)
            if (this.IDsNotToBeDeleted.Contains(item.Id.ToString()))
                e.Cancel = true;
                e.Messages.Add(CreateWarningMessage(item.ContentType.Name));
                break;
    private void ContentService_Trashing(IContentService sender, MoveEventArgs<IContent> e)
        foreach (var moveInfoItem in e.MoveInfoCollection)
            if (this.IDsNotToBeDeleted.Contains(moveInfoItem.Entity.Id.ToString()))
                e.Cancel = true;
                e.Messages.Add(CreateWarningMessage(moveInfoItem.Entity.Name));
                break;
    private static EventMessage CreateWarningMessage(string name)
        var eventMessage = new EventMessage("Warning", string.Format("Can not delete {0}", name), EventMessageType.Error);
        return eventMessage;
    The message appears for the Trashing event (content), but doesn't work for Unpublishing event (content), the Unpublish button just hangs with the spinner spinning, and in the console I get the following error:
    Failed to load resource: the server responded with a status of 400 (Bad Request) - http://localhost:888/umbraco/backoffice/UmbracoApi/Content/PostUnPublish?id=1066
    With Media Trashing event, I get a similar problem - no message is displayed and an error appears in the console:
    POST http://localhost:888/umbraco/backoffice/UmbracoApi/Media/DeleteById?id=1129 400 (Bad Request)
    Any information on how to get these working would be great :-)
    Cheers!
