  • Bendik Engebretsen 105 posts 202 karma points
    Oct 31, 2016 @ 14:35
    Bendik Engebretsen
    Custom section in backoffice - ng-model not passed back to controller
    First of all: I'm very new to Umbraco backoffice extensions and AnguarJS.
    What I have achieved, by following this series of articles, is to create a new section, show the content tree (left pane) and an angular form on the right. Here is the controller and view code:
    edit.controller.js:
    angular.module("umbraco").controller("XmlExport.XmlExportEditController",
    function ($scope, $routeParams, xmlExportResource, notificationsService, navigationService) {
        $scope.loaded = false;
        if ($routeParams.id == -1) {
            $scope.node = {};
            $scope.loaded = true;
        else {
            xmlExportResource.getById($routeParams.id).then(function (response) {
                $scope.node = response.data;
        $scope.exportFilename = "Havneguiden.xml";
        $scope.xmlExport = function (node, exportFilename) {
            xmlExportResource.xmlExport(node.Id, exportFilename).then(function (response) {
                $scope.contentForm.$dirty = false;
                navigationService.syncTree({ tree: 'xmlExportTree', path: [-1, -1], forceReload: true });
                notificationsService.success("Success", node.Name + " has been exported");
    edit.html:
    <form name="contentForm"
      ng-controller="XmlExport.XmlExportEditController"
      ng-show="loaded"
      ng-submit="xmlExport(node, exportFilename)"
      val-form-manager>
    <umb-panel>
        <umb-header>
            <div class="span7">
                <h1>{{node.Name}}</h1>
            <div class="span5">
                <div class="btn-toolbar pull-right umb-btn-toolbar">
                    <umb-options-menu ng-show="currentNode"
                                      current-node="currentNode"
                                      current-section="{{currentSection}}">
                    </umb-options-menu>
        </umb-header>
        <div class="umb-panel-body umb-scrollable row-fluid">
            <div class="tab-content form-horizontal" style="padding-bottom: 90px">
                <div class="umb-pane">
                    <umb-control-group label="Type" description="Content type">
                        <div class="umb-editor umb-textstring">{{node.Template.Alias}}</div>
                    </umb-control-group>
                    <umb-control-group label="Filename" description="Export filename">
                        <input type="text" class="umb-editor umb-textstring" ng-model="exportFilename" required />
                    <div class="umb-tab-buttons" detect-fold>
                        <div class="btn-group">
                            <a class="btn" ng-href="#/content/content/edit/{{node.Id}}">
                                Show
                            </a>
                            <button type="submit" data-hotkey="ctrl+s" class="btn btn-success">
                                Export
                            </button>
    </umb-panel>
    The thing that is not working is passing the value of the < input ng-model="exportFilename" > back to the controller. As you can see, I'm trying to pass the value as a parameter to the ng-submit function "xmlExport", but this does not work, exportFilename is always undefined when entering the controller function. But, the other way is working fine: When initializing the $scope.exportFilename in the Controller, that value is shown in the < input> when entering the form.
    I painfully aware that this problem is probably due to my lack of basic angular knowledge. However, I have spent most of the day on forums trying to figure it out, without any luck. While searching for an answer, I also got a feeling that it could be something special with Umbraco here, but I could be wrong.
    So now, I'm hoping that some v7 backoffice guru here could help me out.
  • Comment author was deleted
    Oct 31, 2016 @ 14:53
    Hey, you don't need to pass it since it's available in $scope.exportFilename so you can just change the ng-submit to
    ng-submit="xmlExport(node)"
    and the function to
     $scope.xmlExport = function (node) {
            xmlExportResource.xmlExport(node.Id, $scope.exportFilename).then(function (response) {
    Oct 31, 2016 @ 16:54
    Bendik Engebretsen
    Ah, so simple! (I thought I had tried it, but obviously I didn't get it right.) Thanks a lot, Tim!
    Oct 31, 2016 @ 16:55
    No prob glad I could help :)
