My question: Is there a way in umbraco to trigger a method to be called (endpoint, etc) on each instance?
Since Umbraco registers each instance in the UmbracoServer table, how is Umbraco generating the computerName field? I could use this table and the job scheduler to do it.
It looks something like this:
RD000223F8055EB//LM/W3SVC/1785223127/ROOT
RD000223F8055EB is the machine name but the rest I'm not sure if there is a method that is exposed to generate the full string so it can be compared on each instance?
Trigger method on each instance of web farm
Hi Lucuma,
What you need is a cache refresher : https://our.umbraco.org/documentation/Reference/Cache/#icacherefresher
Unfortunatly it's not well documented.
But here is a sample of cacherefresher : https://github.com/Jeavon/SEOCheckerCacheRefresher
If you need more examples I can look one up for you.
Dave
