...which is getting me closer, so I now have this code:
var contentType = Services.ContentTypeService.GetContentType("location");
var contents = Services.ContentService.GetContentOfContentType(contentType.Id);
try
var locations = contents.Where(x => x.Published
&& (x.GetValue<string>("City").ToLower() == model.City.ToLower() || string.IsNullOrWhiteSpace(model.City))
&& (Services.DataTypeService.GetPreValueAsString(Convert.ToInt32(x.GetValue<string>("State"))) == model.State || string.IsNullOrWhiteSpace(model.State)))
.Select(t => new Location
Name = t.Name,
StreetAddress = t.GetValue<string>("StreetAddress"),
State = umbraco.library.GetPreValueAsString(Convert.ToInt32(t.GetValue<string>("State"))),
Postcode = t.GetValue<int>("Postcode"),
City = t.GetValue<string>("City"),
Phone = t.GetValue<string>("Phone"),
Id = t.Id,
Geolocation = JsonConvert.DeserializeObject<Geolocation>(t.GetValue("geocoder").ToString())
}).ToList();
return locations;
catch (Exception ex)
Logger.Error(this.GetType(), ex.Message, ex);
throw;
But I get this error:
2016-11-23 00:46:11,628 [P11604/D48/T68] ERROR LocatorApiController - Object reference not set to an instance of an object.
at LocatorApiController.<>cDisplayClass2_0.0(IContent x) in C:\Repositories...\Controllers\LocatorApiController.cs:line 91
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at LocatorApiController.SearchLocation(LocatorFormViewModel model) in C:\Repositories...\Controllers\LocatorApiController.cs:line 91
Get prevalues of dropdown using ContentService
Hi all,
Using the ContentService, I found that my dropdown was returning an int instead of the actual string value entered as the prevalue.
I found this page:
https://our.umbraco.org/forum/using-umbraco-and-getting-started/76225-getting-the-correct-value-from-a-dropdown
2016-11-23 00:46:11,628 [P11604/D48/T68] ERROR LocatorApiController - Object reference not set to an instance of an object. System.NullReferenceException: Object reference not set to an instance of an object. at LocatorApiController.<>cDisplayClass2_0.0(IContent x) in C:\Repositories...\Controllers\LocatorApiController.cs:line 91 at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at LocatorApiController.SearchLocation(LocatorFormViewModel model) in C:\Repositories...\Controllers\LocatorApiController.cs:line 91
Not sure how to fix this?
Thanks, Chris
