  • Graham Carr 5 posts 75 karma points
    Nov 24, 2016 @ 09:42
    Graham Carr
    Problem upgrading from 7.1.9 to 7.5.4
    I am having an issue when trying to upgrade either through Nuget or manually, after merging files, etc. I eventually get to a point whereby when I launch the website for the first time locally using http://localhost:81 (this works fine before the upgrade), I keep receiving the error message below.
    The URL that is being redirected to is as follows:
    http://localhost:81/install?redir=true&url=http%3a%2f%2flocalhost%3a81%2f
    If I try to access the backend I also get the same message. I downloaded a copy of the Umbraco source and upon debugging can see in the file WebSecurity.cs of Umbraco.Web that the method IsAuthenticated() is showing null for the _httpContext.User.
    Any ideas what the issue might be??
       Umbraco.Web.Security.WebSecurity.IsAuthenticated() +19
       Umbraco.Web.Security.WebSecurity.ValidateCurrentUser(Boolean throwExceptions) +17
       Umbraco.Web.Install.Controllers.InstallController.Index() +142
       lambda_method(Closure , ControllerBase , Object[] ) +35
       System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) +14
       System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +157
       System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +27
       System.Web.Mvc.Async.AsyncControllerActionInvoker.<BeginInvokeSynchronousActionMethod>b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState) +22
       System.Web.Mvc.Async.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult) +29
       System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) +32
       System.Web.Mvc.Async.AsyncInvocationWithFilters.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3d() +50
       System.Web.Mvc.Async.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() +225
       System.Web.Mvc.Async.<>c__DisplayClass33.<BeginInvokeActionMethodWithFilters>b__32(IAsyncResult asyncResult) +10
       System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) +34
       System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +26
       System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +100
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +27
       System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +13
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29
       System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +36
       System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult asyncResult, Controller controller) +12
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +22
       System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26
       System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10
       System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +21
       System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28
       System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9644097
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
  • Pierre Bakker 3 posts 23 karma points
    Nov 08, 2017 @ 05:47
    Pierre Bakker
    I have the exact same problem when upgrading from 7.6.6 to 7.7.7. also tried to upgrade to a lower version (7.6.11 and 7.6.7) but both have the exact same issue.
    Did you find a solution for this problem?
    thnx Pierre
