  • Denis 25 posts 267 karma points
    Nov 25, 2016 @ 08:34
    Denis
    How to create media content using ContentService?
    I have following code:
    var product = contentService.CreateContent(
          name, // the name of the product
          1000, // the parent id should be the id of the group node
         "product", // the alias of the product Document Type
    Which arguments do I need to pass in CreateContent method for media creation?
    Thanks.
    Nov 25, 2016 @ 08:59
    Dennis Aaen
    2
    Hi Denis,
    Have you seen the media service, where you will find a create method. https://our.umbraco.org/documentation/reference/management/services/mediaservice
    We also have a Umbraco TV chapter about the Media API. https://umbraco.tv/videos/umbraco-v7/developer/fundamentals/media-api/introduction/
    Hope this helps,
    /Dennis
    Nov 25, 2016 @ 09:35
    Denis
    Dennis, thanks for your help. Do you know which one of MediaService's methods I can use for adding existing media to Umbraco? I need to move all of the contents from one Umbraco instance to another.
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Nov 26, 2016 @ 20:26
    Dennis Adolfi
    Hi Denis.
    Check out Kevin's answer in this thread: https://our.umbraco.org/forum/developers/api-questions/47792-Create-Media-Programmatically-in-V7#comment-170995
    I think that might be what you're looking for.
    Best of luck!
