  • Max 80 posts 437 karma points
    Nov 28, 2016 @ 15:03
    Max
    2
    Custom Section - Reuse Datatype dropdownlist
    I'm trying to reuse a custom datatype in my custom section... I've been following a few different tutorials and have have successfully gotten my user control rendering with the correct prevalues. However, I cannot figure out how to set the dropdown value when I load an existing record.
    i'm initializing the datatype control model:
    angular.module("umbraco").controller("BoardMember.editController", function ($scope, $routeParams, boardMemberResource, notificationsService, navigationService, entityResource, dataTypeResource) {
        $scope.board_titles = []; // { model: {} };
    var bt_model = {
        alias: "board_title",
        label: "Board Position",
        view: "dropdown",
        description: 'Enter the position on the board this member currently holds.',
        config: {
            items: [],
            multiple: false,
            hideLabel: true
        hideLabel: true,
        value: "",
        existingValue: null,
        hasValue: false
    ... Then if a record is being edited:
     // GET BOARD MEMBER POSITION
            dataTypeResource.getByName("Commissioner - Title - Dropdown list").then(function (datatype) {
                $scope.board_titles[0] = {
                    model: bt_model,
                    alias: "xxxxx",
                    label: "weeeeeeeeeee",
                    hideLabel: true,
                    existingValue: $scope.model.boardMember.board_title
                $scope.board_titles[0].model.config = {
                    items: datatype.preValues[0].value,
                    multiple: false,
                    hideLabel: true
                $scope.board_titles[0].model.value = $scope.model.boardMember.board_title;
    ... my custom view for the section looks like this:
     <umb-control-group ng-if="loaded" label="Board Position" >
             <umb-property ng-repeat="bt in board_titles" property="bt">
                    <umb-editor model="bt.model" ></umb-editor>
             </umb-property>
     </umb-control-group>
    Is there an "easier" way or a "more appropriate" way to accomplish this task (reusing custom datatypes in sections)?
    Nov 28, 2016 @ 15:04
    Max
    One thing I noticed, when the form is rendered the dropdown control is given the name "dropdownlist" from the view, not my alias...some of my model properties have been created as a part of my testing...
    Nov 28, 2016 @ 18:47
    Max
    This is what has been rendered.
    This is a screen shot of whats being rendered...
    Dec 02, 2016 @ 14:06
    Max
    So I've figured a few things out... The model="model.value" needs to be an object:
     $scope.board_titles[0].model.value = {value,"[your value]", sortOrder="n"};
    I had to create a custom property editor essentially. I copied the dropdown.html from Umbraco/views/propertyeditors/ as the foundation for my custom dropdown editor:
    <div ng-controller="BoardMember.BoardPositionDropdownController" ng-switch="model.config.multiple">
        <select name="dropDownList{{model.alias}}"
                class="umb-editor umb-dropdown"
                ng-switch-default
                ng-model="model.value"
                ng-options="item.id as item.value for item in model.config.items track by item.value"
                ng-change="changed()">
        </select>
        <span ng-model="model.value"></span><span ng-bind="model.value"></span>
    Note the select name property: I tacked on my property model.alias to avoid any DOM conflicts that might occur (this was an edit from the Umbraco view).
    I also added the "..track by..." statement to the ng-options.
    Now my dropdown is loading the prevalues from my custom datatype I created in the Developer / datatypes area of the backoffice... and my saved record in the database is loading the correct value on the edit page...However...when I change or select a new option, the select control clears itself, the list is still there, but no values can be actually selected...
    I put a function on ng-change and write $scope.model to console and it's now undefined...
    Dec 05, 2016 @ 14:14
    Max
    So after a bit more debugging I had to add a $watch to the controller for my custom view:
    .controller("BoardMember.BoardPositionDropdownController",
    function ($scope) {
        var _mod = this;
        var _scp = $scope;
        $scope.$watch('model.value', function (newVal, oldVal, scope) {
            scope.model.value = (typeof newVal === "undefined") ? oldVal : newVal;
    So now it loads my saved value, and I can selected the new value if I want to edit it... BUT NOW... I can't find the new value in scope to pass to my parent controller scope...
    Dec 06, 2016 @ 15:06
    Max
    well... I solved the final issue of not being able to save the selected value upon editing...
    Changed to (removed "item.id as"):
     ng-options="item.value for item in model.config.items track by item.value"
