Hi fellow Umbracians!
this is my first post so bear with me :)
I have a problem with my internal and external index, 1 - 2 times a month the indexes becomes corrupt and this error message shows in the logs:
2016-12-23 10:28:00,653 [P3380/D6/T91] ERROR UmbracoExamine.DataServices.UmbracoLogService - Provider=InternalIndexer, NodeId=-1
System.Exception: App is shutting down so index batch operation is ignored,, IndexSet: InternalIndexSet
My application rebuilds two other indexes that stores est. 100,000 articles each every night and they work properly.
The Internal and External indexes stores est. 20-50 sets.
The issue is azure webapps moving around. We had this on a site. So when in azure you setup you have to do a few things that are different from out of box setup.
Hi Ismail,
Thanks for the replay but I have already changed those settings and still gets this problem.
I tried to open one of the corrupt indexes with Luke and had no problem searching in it.
Same goes if I go to the Developer section in Umbraco and try to search with the Examine Management tools in the Internal index, but if i search for content in the content tree I don´t get anything at all :(
Examine, Corrupt Internal and external Index
Hi fellow Umbracians! this is my first post so bear with me :)
I´m running the application in Azure webapps.
My indexes:
IndexProviders:
IndexSearchProviders:
I will send a big hug to any who helps me crack this case ;)
Cheers /Nick
Hi Niklas,
The same issue here, so +1
Details: VPS server, Umbraco 7.5.6, Win 2012 R2, IIS 8.5, default config setup (I'm not using Examine, but I see this error often while publishing)
Bojan
+1
Niklas,
See here for full details https://our.umbraco.org/Documentation/Getting-Started/Setup/Server-Setup/azure-web-apps
Regards
Ismail
Hi Ismail, Thanks for the replay but I have already changed those settings and still gets this problem.
I tried to open one of the corrupt indexes with Luke and had no problem searching in it. Same goes if I go to the Developer section in Umbraco and try to search with the Examine Management tools in the Internal index, but if i search for content in the content tree I don´t get anything at all :(
Hope this info can help ;)
/Nick
We are seeing this on dedicated server windows 2012 umbraco 7.5.7
Was this issue ever solved?
We are experiencing a similar issue.
