We are developing some Umbraco websites for our clients and we host our applications on Azure.
Most of the time, the selected plans are with auto-scale and we set up a master server for the back end.
In our code, sometimes, we are required to import data from external sources into Umbraco and we use the ContentService. Here is an example :
var node = UmbracoContext.Current.Application.Services.ContentService.CreateContent(data.Name, parent, "details");
node.SetValue("myProperty", data.TheValue);
UmbracoContext.Current.Application.Services.ContentService.SaveAndPublishWithStatus(node);
Can we do this on a load balanced hosting ? Is the ContentService safe or do we have to run these jobs on only one instance ?
Thanks a lot for your help, I did not find any information about this and we have some of our database that gets corrupted without any reason. We think that this could be an issue, but not sure.
Load Balancer and call to the ContentService
Hello all,
We are developing some Umbraco websites for our clients and we host our applications on Azure. Most of the time, the selected plans are with auto-scale and we set up a master server for the back end.
Simon
Just asked essentially this question of Umbraco. +1 to this forum post (will post if I get a solution)
My query was how do we make sure a service func called from the frontend is processed on the master.
A possible solution, for example, based on hangfire on any other queue
