  • Sean Dooley 289 posts 528 karma points
    Jan 30, 2017 @ 14:29
    Sean Dooley
    Edit content node inside Custom section
    I'm looking at creating a custom section to display content nodes waiting for approval.
    Instead of redirecting the user from my custom section to the Content section, I would like to be able to edit the node within the custom section.
    Is it possible to display the edit view for a node inside a custom section?
  • David Peck 690 posts 1896 karma points c-trib
    Jan 30, 2017 @ 22:20
    David Peck
    Almost certainly yes. You've presumably Googled custom sections right?
    This has a demo project: http://www.nibble.be/?p=440
    You should be able to unpick this to get your tree to load /umbraco/views/content/edit.html.
    Jan 31, 2017 @ 08:26
    Sean Dooley
    Thanks David. I've got the edit form rendering now.
    The next issue to tackle is an authorization error when attempting to save the content node. I am getting the following error
    Unauthorized access to URL: /umbraco/backoffice/UmbracoApi/Content/PostSave
    Below is the code for my edit.controller.js where I'm trying to use contentResourcesend.ToPublish(content, isNew, files)
    angular.module("umbraco")
    .controller("StagingEditController",
        function ($scope, $routeParams, $http, contentResource, notificationsService) {
            $scope.loaded = false;
            $scope.page = {};
            if ($routeParams.id === -1) {
                $scope.content = {};
                $scope.loaded = true;
            } else {
                contentResource.getById($routeParams.id)
                    .then(function (response) {
                        $scope.content = response;
            $scope.preview = function(content) {
                console.log('preview', content);
            $scope.save = function(content) {
                contentResource.sendToPublish(content, false, [])
                    .then(function(response) {
                        console.log('sendToPublish', response);
                        notificationsService.success("Document sent for approval", "");
                    }, function(err) {
                        notificationsService.success(err, "");
    Below is the code for my edit.html. Some elements are commented out while I'm attempting to put all of this together.
    <div ng-controller="StagingEditController">
    <umb-panel>
        <umb-header>
            <umb-content-name ng-model="content.name" />
        </umb-header>
        <div class="umb-panel-body umb-scrollable row-fluid">
            <div class="tab-content">
                <div class="umb-pane">
                    <!--<iframe src="#/content/content/edit/{{content.id}}" style="width: 100%; height: 100%;"></iframe>-->
                    <div class="umb-tab-buttons">
                        <div class="btn-group">
                            <a class="btn" ng-href="#/content/content/edit/{{content.id}}">Edit</a>
        <form name="contentForm"
              ng-submit="save(content)"
              novalidate
              val-form-manager>
            <umb-editor-view umb-tabs>
                <umb-editor-header menu="page.menu"
                                   name="content.name"
                                   tabs="content.tabs"
                                   hide-icon="true"
                                   hide-description="true"
                                   hide-alias="true">
                </umb-editor-header>
                <umb-editor-container>
                    <umb-tabs-content class="form-horizontal" view="true">
                        <umb-tab id="tab{{tab.id}}" ng-repeat="tab in content.tabs" rel="{{tab.id}}">
                            <umb-property ng-repeat="property in tab.properties" property="property">
                                <umb-editor model="property"></umb-editor>
                            </umb-property>
                        </umb-tab>
                    </umb-tabs-content>
                </umb-editor-container>
                <umb-editor-footer>
                    <umb-editor-footer-content-left>
                        <umb-breadcrumbs ng-if="ancestors && ancestors.length > 0"
                                         ancestors="ancestors"
                                         entity-type="content">
                        </umb-breadcrumbs>
                    </umb-editor-footer-content-left>
                    <umb-editor-footer-content-right>
                        <!--<umb-button ng-if="page.listViewPath"
                                    type="link"
                                    href="#{{page.listViewPath}}"
                                    label="Return to list"
                                    label-key="buttons_returnToList">
                        </umb-button>-->
                        <umb-button ng-if="!page.isNew && content.allowPreview"
                                    type="button"
                                    action="preview(content)"
                                    label="Preview page"
                                    label-key="buttons_showPage">
                        </umb-button>
                        <!--<umb-button-group ng-if="defaultButton"
                                              default-button="defaultButton"
                                              sub-buttons="subButtons"
                                              state="page.buttonGroupState"
                                              direction="up"
                                              float="right">
                        </umb-button-group>-->
                        <umb-button type="button"
                                    action="save(content)"
                                    state="page.saveButtonState"
                                    button-style="success"
                                    shortcut="ctrl+s"
                                    label="Send to publish"
                                    label-key="buttons_save">
                        </umb-button>
                    </umb-editor-footer-content-right>
                </umb-editor-footer>
            </umb-editor-view>
        </form>
    </umb-panel>
    Hopefully someone will be able to point me in the right direction on this.
    Jan 31, 2017 @ 09:04
    David Peck
    Sorry, not my area but I note that Umbraco is passing back properties that you're not.
    contentEditingHelper.contentEditorPerformSave({
            statusMessage: args.statusMessage,
            saveMethod: args.saveMethod,
            scope: $scope,
            content: $scope.content,
            action: args.action
        }).then(function (data) {
            //success
            init($scope.content);
            syncTreeNode($scope.content, data.path);
            $scope.page.buttonGroupState = "success";
            deferred.resolve(data);
        }, function (err) {
            //error
            if (err) {
                editorState.set($scope.content);
            $scope.page.buttonGroupState = "error";
            deferred.reject(err);
    Also it is using contentEditingHelper
