  • Tom 713 posts 954 karma points
    Jan 31, 2017 @ 00:42
    Tom
    Right way to get an instance of DataTypeService 7.5.8
    Hi All, We have just upgraded to 7.5.8 and are using the datatypeservice as part of a migration.
    I was wondering what the right way to grab an instance of it was whereas previously it looked like:
    var dts = new DataTypeService(); var dropdownValueToSet = dts.GetPreValuesCollectionByDataTypeId(templateVariantsDropdownDatatypeId).PreValuesAsDictionary .First(d => d.Value.Value == templateVariantName).Value.Id;
    The method sig has changed and I'm not sure how to initialise the dependencies for the UOW, repository factory etc.
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    Jan 31, 2017 @ 11:03
    Alex Skrypnyk
    Hi Tom
    The best way is to use standalone context of Umbraco like:
    var dropdownValueToSet = ApplicationContext.Services.DataTypeService.GetPreValuesCollectionByDataTypeId(templateVariantsDropdownDatatypeId).PreValuesAsDictionary.First(d => d.Value.Value == templateVariantName).Value.Id;
    You don't need to create a new instance of Services I think.
    Just use what we have in context.
    Alex
    Jan 31, 2017 @ 17:45
    Alex Skrypnyk
    Hi Tom
    Did you find solution?
    Is it working for you?
    Alex
    Jan 31, 2017 @ 20:36
    Tom
    Hi Alex, Yes that worked perfectly thanks very much :)
