A bit more info about this issue from my colleague. I debugged the Umbraco source code and I discovered that UmbracoContext.Current.InPreviewMode always returns false. Even after pressing the preview button.
In the DetectInPreviewModeFromRequest method Security.CurrentUser returns null. Going a few methods deeper the problem is in the AuthenticationExtensions.cs GetCurrentIdentity method.
The problem lies in this code:
//Check if there's more than one identity assigned and see if it's a UmbracoBackOfficeIdentity and use that
var claimsPrincipal = http.User as ClaimsPrincipal;
if (claimsPrincipal != null)
backOfficeIdentity = claimsPrincipal.Identities.OfType<UmbracoBackOfficeIdentity>().FirstOrDefault();
if (backOfficeIdentity != null) return backOfficeIdentity;
When I debug this code with <add key="owin:appStartup" value="UmbracoDefaultOwinStartup" /> in the web.config claimsPrincipal.Identities has 2 items:
When I debug with <add key="owin:appStartup" value="Site.Owin.Startup" /> in the web.config claimsPrincipal.Identities only has 1 item:
[0] = {System.Security.Principal.GenericIdentity}
So somehow when we use our own OwinStartup with app.UseOAuthBearerAuthentication(new OAuthBearerAuthenticationOptions()); we're missing Umbraco.Core.Security.UmbracoBackOfficeIdentity. We need this code for token based authentication.
Do we need to configure something extra to get the correct backoffice identity?
[assembly: OwinStartup(typeof(Site.Owin.Startup))]
namespace Site.Owin
public class Startup : UmbracoDefaultOwinStartup
public override void Configuration(IAppBuilder app)
base.Configuration(app);
// We need to set these values again after our custom changes. Otherwise preview doesn't work.
app.UseUmbracoBackOfficeCookieAuthentication(this.ApplicationContext)
.UseUmbracoBackOfficeExternalCookieAuthentication(this.ApplicationContext)
.UseUmbracoPreviewAuthentication(this.ApplicationContext);
We thought we didn't need to set those values because they we're already being set in base.Configuration(app);, but they need to be set again after we made some changes to IAppBuilder.
Preview not working when using custom Startup file with app.UseOAuthBearerAuthentication
Hello everyone,
I'm working on a project where we use OAuth bearer authentication to secure some of the web APIs.
Everything works fine, except for the preview in Umbraco. The startup class looks like this:
The web.config app setting looks like this:
As soon as I remove app.UseOAuthBearerAuthentication the preview works again. Any ideas on this?
UmbracoContext.Current.InPreviewModealways returns false. Even after pressing the preview button.In the
DetectInPreviewModeFromRequestmethodSecurity.CurrentUserreturns null. Going a few methods deeper the problem is in the AuthenticationExtensions.csGetCurrentIdentitymethod.The problem lies in this code:
<add key="owin:appStartup" value="UmbracoDefaultOwinStartup" />in the web.configclaimsPrincipal.Identitieshas 2 items:When I debug with
<add key="owin:appStartup" value="Site.Owin.Startup" />in the web.configclaimsPrincipal.Identitiesonly has 1 item:So somehow when we use our own OwinStartup with
app.UseOAuthBearerAuthentication(new OAuthBearerAuthenticationOptions());we're missingUmbraco.Core.Security.UmbracoBackOfficeIdentity. We need this code for token based authentication.Do we need to configure something extra to get the correct backoffice identity?
Jeroen
If was fixed by doing the same thing as in this topic: https://our.umbraco.org/forum/extending-umbraco-and-using-the-api/80088-preview-with-custom-backoffice-authentication
This is the code now:
base.Configuration(app);, but they need to be set again after we made some changes to IAppBuilder.Jeroen
If you have a look at the source there are better methods to override for what you need: https://github.com/umbraco/Umbraco-CMS/blob/dev-v7/src/Umbraco.Web/UmbracoDefaultOwinStartup.cs
override
ConfigureMiddlewarefor dealing with middleware, overrideConfigureServicesfor configuring services for the OWIN contextYou must also make sure you call everything including
.FinalizeMiddlewareConfiguration();Thank Shannon,
It's now solved like this:
Jeroen
Thank you for providing this information!
