  • Alistair Kidd 2 posts 72 karma points
    Feb 15, 2017 @ 21:44
    Alistair Kidd
    Using Runtime Cache with Umbraco
    I've been adding caching to a new-ish Umbraco application as part of performance improvement project. As advised in the documentation i've used the Umbraco helper method(s).
    https://our.umbraco.org/documentation/reference/cache/updating-cache
    However, I've also found some existing code that uses HttpContext.Current.Cache directly which contradicts the following:
    "You shouldn't be using HttpRuntime.Cache or HttpContext.Current.Cache directly, you should always be accessing it via the ApplicationContext.ApplicationCache object"
    Should i be concerned about this and re-write to use the Umbraco caching implementation or can i happily leave the code alone?
    Any thoughts would be appreciated.
    Alistair
  • Alex Skrypnyk 6179 posts 24240 karma points MVP 8x admin c-trib
    Aug 01, 2018 @ 08:34
    Alex Skrypnyk
    Hi Alistair
    Can you share with our community how did you do a caching and what pitfalls, maybe?
    Alex
