using System.ComponentModel.DataAnnotations;
using System.Web;
namespace BootstrappedDNDCC.Models
public class RegisterModel
[Required]
public string Name { get; set; }
[Required]
[EmailAddress]
public string Email { get; set; }
[Required]
public string Password { get; set; }
public string Biography { get; set; }
public HttpPostedFileBase Avatar { get; set; }
And the controller (RegisterMemberSurfaceController.cs):
using System.Web.Mvc;
using Umbraco.Web.Models;
using Umbraco.Web.Mvc;
namespace BootstrappedDNDCC.Controllers
public class RegisterMemberSurfaceController : SurfaceController
// GET: RegisterMemberSurface
public ActionResult Register(RegisterModel model)
if (!ModelState.IsValid)
return CurrentUmbracoPage();
var memberService = Services.MemberService;
if (memberService.GetByEmail(model.Email) != null)
ModelState.AddModelError("", "A member with that email already exists");
var member = memberService.CreateMember(model.Email, model.Email, model.Name, "registeredMember");
member.SetValue("userProfileBio", model.Biography);
member.SetValue("userProfileAvatar", model.Avatar);
memberService.SavePassword(member, model.Password);
Members.Login(model.Email, model.Password);
memberService.Save(member);
return Redirect("/");
The Email, Password and Name values are recognized by the controller, but the Biography and the Avatar properties arent.
I'm getting the following error:
Error CS1061 'RegisterModel' does not contain a definition for 'Biography' and no extension method 'Biography' accepting a first argument of type 'RegisterModel' could be found (are you missing a using directive or an assembly reference?) BootstrappedDNDCC E:\Projects\Sites\BootstrappedDNDCC\BootstrappedDNDCC\Controllers\RegisterMemberSurfaceController.cs 25 Active
I followed the tutorials strictly, since I'm all green to working with the APIs and controller/models for that matter.
In my view, the values are recognized, so the problem lies only within the controller as far as I can tell.
Am I supposed to do something special when I start up VS? I tried rebuilding the solution and project, but still no connection, so to say.
Hope you guys can help me in the right direction, cus I feel a bit lost at the moment :)
Umbraco defines it's own RegisterModel in Umbraco.Web.Models. Your code is using this model instead of your custom one. Update your Register method signature as follows and it should work:
public ActionResult Register(BootstrappedDNDCC.Models.RegisterModel model)
Custom member properties not defined in controller
Hi guys
I'm watching the Umbraco.tv Member section, and I've run into some trouble.
I've added a few extra custom member properties, as done in the tutorial, but my model simply don't recognize the custom values.
My code is as follow:
The view (MemberRegister.cshtml):
The model (RegisterMemberViewModel.cs):
Thank you in advance
Best
Henrik
Hi Henrik,
RegisterModelinUmbraco.Web.Models. Your code is using this model instead of your custom one. Update yourRegistermethod signature as follows and it should work:Steven
James
You are my savior!
Stared into the code for so long and I simply couldn't figure out where I went wrong, since some of the props were defined.
Thank you very much for the quick reply.
Have a great evening :)
Best
Henrik
