I'm on 7.4.3 and have written a new backoffice section / application.
I've put a link in my edit.html to the content section, which works, and a link to the users section which doesn't.
Here's the link that works:
<a class="btn" ng-href="#/content/content/edit/{{node.Id}}"> Show </a>
and here's the link that doesn't:
<a class="btn" ng-href="#/users/users/edit/{{node.WriterId}}"> {{userName}} </a>
The error I get is
umbraco request error: the url a 404 (not found) returned views/users/edit
... which seems to be looking for "views/users/edit" and not "users/users/edit"
Any help would be appreciated.
Hi MuirisOG,
The deep link to the user edit form is slightly different because it is presented within a frame. Try the following:
<a class="btn" ng-href="#/users/framed/%252Fumbraco%252Fusers%252FeditUser.aspx%253Fid%253D{{node.WriterId}}">
Steven
Hi Steven,
that has done the trick.
I thought I could use #/users/users/edit because this is how the links work in the users section, and I figured it would work the same way as the content section.
#/users/users/edit
I can see the link changes in the address bar after you have clicked it.
many thanks
Muiris
Problem from my Custom Backoffice Application
The error I get is
Hi MuirisOG,
Steven
Hi Steven,
#/users/users/editbecause this is how the links work in the users section, and I figured it would work the same way as the content section.I can see the link changes in the address bar after you have clicked it.
many thanks
Muiris
