  • Niels Henriksen 74 posts 277 karma points
    Mar 08, 2017 @ 13:55
    Niels Henriksen
    Visual Studio project to extend Umbraco
    Are there some where a project to open in Visual Studio for making a new section/menu in Umbraco?
  • Nigel Wilson 945 posts 2077 karma points
    Mar 09, 2017 @ 22:30
    Nigel Wilson
    Hi Niels
    I have the Tag Manager package on Bitbucket which I could share with you if that would be helpful.
    The solution has a separate project for the plugin which creates a separate section in the admin area, and then a SQL database site, and also a SQL-CE based site. The build tasks and project references do the copying of required files from the plugin project to the web projects.
    If you have a bitbucket account, let me know your login and I can share with you - nigel@optimised.net.nz
    Cheers, Nigel
    Mar 09, 2017 @ 22:35
    Niels Henriksen
    That sounds nice Nigel :)
