I added a bunch of fields to my member type.
Umbraco will not regenerate the model now, just produces an error telling me to check the u log.
I checked the log in the db and nothing. I checked the txt log files and got the following information below, which had no model problems, I also tried generating from the models builder on the dev tab and it did not throw any errors but also did not regenerate the member model.
--edit--
Initially it would not show any form of error message, I changed to livedll model mode and this is what I got:
2017-03-13 16:28:28,371 [P11112/D4/T13] ERROR Umbraco.ModelsBuilder.Umbraco.LiveModelsProvider - Failed to generate models.
Umbraco.ModelsBuilder.Building.CompilerException: Duplicate 'PublishedContentModel' attribute
at Umbraco.ModelsBuilder.Building.Compiler.ThrowExceptionFromDiagnostic(IDictionary`2 files, Diagnostic diagnostic) in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Building\Compiler.cs:line 154
at Umbraco.ModelsBuilder.Building.Compiler.Compile(String assemblyName, IDictionary`2 files, Stream stream) in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Building\Compiler.cs:line 131
at Umbraco.ModelsBuilder.Building.Compiler.Compile(String assemblyName, IDictionary`2 files, String binPath) in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Building\Compiler.cs:line 79
at Umbraco.ModelsBuilder.Umbraco.ModelsBuilderBackOfficeController.GenerateModels(String modelsDirectory, String bin) in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Umbraco\ModelsBuilderBackOfficeController.cs:line 134
at Umbraco.ModelsBuilder.Umbraco.LiveModelsProvider.GenerateModels() in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Umbraco\LiveModelsProvider.cs:line 103
at Umbraco.ModelsBuilder.Umbraco.LiveModelsProvider.GenerateModelsIfRequested(Object sender, EventArgs args) in X:\Projects\Umbraco\ModelsBuilder\Zbu.ModelsBuilder\Umbraco.ModelsBuilder\Umbraco\LiveModelsProvider.cs:line 82
I presume it is getting hung up on models that already exist?
Member types not being generated by model builder
I added a bunch of fields to my member type. Umbraco will not regenerate the model now, just produces an error telling me to check the u log.
--edit--
Hi Damien,
Models build is able to generate models for members. Does your member type have the same alias perhaps as one of your content types ?
That could be the issue ?
Dave
it's interesting, I can use the updates to the models when I make them editbale by the user.
Model generation still fails though.
I had the same thought as you and I went through everything and no other node has the same value. Maybe I have a property somewhere.
