I've inherited an Umbraco project which employs a Custom Workflow to do some fancy business whenever a form is submitted on the site.
On cloning the GIT repo of the project to a local dev environment for the life of me I cannot get it to trigger or hit any breakpoints I set in the class which inherits : WorkFlowType
I've tried re-saving the forms and re-creating the workflow in the back office. I can see that custom workflows are saved in Json format in
App_Plugins/UmbracoForms/Data/workflows
Do these need to be re-created or re-published elsewhere?
The GIT project should be exactly the same as the deployed site, so I can't understand why this works in production and not locally other than it being an Umbraco/Re-publish related issue?
Nothing is logged because the workflow is never hit.
Spent a bit more time delving into this. The only way I can get it to trigger the workflow is to re-create the entire form, from scratch, then re-attach the workflow.
I have a sneaky suspicion that the json files in App_Plugins/UmbracoForms/Data/workflows are either corrupt or do not get rebuilt correctly.
------EDIT------
I've found two .json files for a form submission and an identical workFlowTypeId and sortOrder both 0 wether this causes a conflict and it's failing silently?
Custom Workflow not being triggered
Any ideas greatly welcome!
Hi Matthieu
Did you manage to figure this one out yet?
Otherwise it might be worth checking the log file and see if there are any entries related to Umbraco forms marked with either ERROR or WARNING.
If you don't use a backoffice log viewer (3rd party packages usually) then try going to /App_Data/Logs/ and open up the file and have a look.
Hope this helps and I'm looking forward to hearing from you.
Cheers, Jan
------EDIT------
Also worth mentioning I'm on Umbraco Forms V4.4.0
