I am creating a search index. I've added a custom field into the index using:
e.Fields.Add("_language", "en");
as a GatheringNodeData event. I can see this field and value when looking inside Luke at the index and I can search for it inside examine management e.g. +_language:en
However, when I search from Examine, I get no results. I have debugged through the code and all fields apart from custom fields are returned by Examine. In that same code, I can search for the usual fields just fine, as soon as I add to search the _language field, nothing is returned.
I'm using Umbraco 7.5.13. Any ideas what I'm doing wrong?
var externalSearcher = ExamineManager.Instance.SearchProviderCollection["MySearcher"];
var criteria = externalSearcher.CreateSearchCriteria(UmbracoExamine.IndexTypes.Content);
var query = criteria.Field("_language", "en");
return ExamineManager.Instance.Search(query.Compile());
If I change to:
var query = criteria.Field("title", "any title here");
It returns search results.
In Luke, I have the results coming through without an issue:
return externalSearcher.Search(query.Compile());
Examine not returning custom fields
Hi everyone.
I am creating a search index. I've added a custom field into the index using: e.Fields.Add("_language", "en");
Thank you.
Francis,
Can you paste back your search code.
Regards
Ismail
Thanks for the reply.
The search code that is running is:
If I change to:
Thanks.
I found the issue. I should have been doing:
rather than using:
Thanks for your help. Hopefully this helps someone else.
