  • Pradeep 8 posts 76 karma points
    May 11, 2017 @ 04:52
    Pradeep
    Memory Full in IIS Load balancing issue
    Please find attachment and need to find an permanent solution on umbraco basis for load balancing concept.
    Now, we have removed that server from load balancer and make only primary server as service.
    Note: setup is running in load balancing environment.main server will works fine, sub server is causing issue.
    May 11, 2017 @ 06:07
    Dave Woestenborghs
    Hi Pradeep,
    If you are saying "same issue occurs", what do you mean by that ?
    Also do you have more information on what triggers this high memory usage ?
    Dave
