First of all I set RebuildOnAppStart =false in examinesettings.config, then I wrote this code:
// EXAMINE
using Examine;
// SYSTEM
using System;
using System.Web.Configuration;
// UMBRACO
using Umbraco.Web.Mvc;
using Umbraco.Web.WebApi;
namespace AF.UmbTasks.Plugins
/// <summary>
/// </summary>
[PluginController("Tasks")]
public class ExamineController : UmbracoApiController
[System.Web.Http.HttpGet]
public string ExamineIndexRebuild(string code)
if (WebConfigurationManager.AppSettings["AFTask_RebuildExamineIndex"] != null)
string examineIndexToRebuild = WebConfigurationManager.AppSettings["AFTask_RebuildExamineIndex"].ToString();
try
//validate the querystring
if (code.Equals(System.Configuration.ConfigurationManager.AppSettings["code"]))
ExamineManager.Instance.IndexProviderCollection[examineIndexToRebuild].RebuildIndex();
string successRebuildMessage = "Examine Index successfully rebuilded: " + examineIndexToRebuild;
Logger.Info(typeof(ExamineController), successRebuildMessage);
catch (Exception ex)
string errorRebuildMessage = "Examine Index NOT rebuilded: " + examineIndexToRebuild;
Logger.Error(typeof(ExamineController), errorRebuildMessage, ex);
return "complete";
When I try to access the URL "/Umbraco/Tasks/Examine/ExamineIndexRebuild?code=MyCodeForSecurity" of my website, the results is a blank xml page (see the attach file)
I don't understand if I must create my custom route (and how) and where I must configure the "code" key.
Can anyone help me?
There is another way to create a task to rebuild the examine index?
// EXAMINE
using Examine;
// SYSTEM
using System;
// UMBRACO
/// <summary>
/// </summary>
[PluginController("AFTasks")]
string rebuildResultMessage = string.Empty;
try
if (!String.IsNullOrEmpty(code))
ExamineManager.Instance.IndexProviderCollection[code].RebuildIndex();
rebuildResultMessage = "AFTask: The Examine Index successfully rebuilded (" + code + ")";
Logger.Info(typeof(ExamineController), rebuildResultMessage);
else
rebuildResultMessage = "AFTask: The Examine Index has not been rebuilt! The Indexer name is missing";
Logger.Error(typeof(ExamineController), rebuildResultMessage, new Exception("Empty or NULL Indexer Name"));
rebuildResultMessage = "AFTask: The Examine Index has not been rebuilt! The \"" + code + "\" indexer does not exist";
Logger.Error(typeof(ExamineController), rebuildResultMessage, ex);
return rebuildResultMessage;
[SOLVED] How to create a Custom Task Plugin to rebuild an Examine Index
I wrote this plugin (based on these instructions) but it doesn't work.
Can anyone help me? There is another way to create a task to rebuild the examine index?
Adriano
SOLVED!!!
I changed my code with following:
