  • Bruno Olsen 75 posts 316 karma points
    Aug 01, 2017 @ 07:44
    Bruno Olsen
    7.6.1: UrlRewriting.config seems not to work
    I'm trying to do some seo-friendly urls but I'm having a bit of trouble. I found that I couldn't get UrlRewriting.config to work on this installation, so I tried another approach which went even worse :)
    So, the build in URL tracker is disabled, Url Tracker is installed - and those things usually doesn't interfere with the use of UrlRwriting.config.
    I was wondering, since the file didn't even come with the download, is UrlRewriting.config not supported anymore?
    Neither
    <add name="JobCodeRule"
        virtualUrl="^~/test/(.*)"
        destinationUrl="~/test/?age=$1"
        rewriteUrlParameter="ExcludeFromClientQueryString"
        ignoreCase="true" />
    nor
    <add name="umb2new"
       redirect="Domain"
       ignoreCase="true" rewriteUrlParameter="IncludeQueryStringForRewrite"
       virtualUrl="http://somedomain/test/"
       redirectMode="Temporary"
       destinationUrl="http://somedomain/testing/" />
    works. The later is just to see if redirects I know SHOULD work actually does.
    Kind regards, Bruno
  • james 37 posts 121 karma points c-trib
    Aug 01, 2017 @ 08:37
    james
    Hi Bruno,
    UrlRewriting.net was removed from 7.6 - it's slow and wasn't being maintained. You can use the IIS URL rewrite module which is much more efficient and should be able to handle your rewrite rules.
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Aug 01, 2017 @ 08:43
    David Brendel
    Hi Bruno,
    is it a fresh install of Umbraco? Then the UrlRewritting.Net is indeed removed.
    If it was an update from a previous v7 version it should still be there as it will not get deleted.
    But even then I would also suggest to switch to the IIS Rewrite Module if possible.
    Regards David
    Aug 01, 2017 @ 08:48
    Bruno Olsen
    Hi James and David
    Ok, thanks :) I'll try the IIS Rewrite Module :)
    Kind regards, Bruno
    Aug 01, 2017 @ 09:07
    Bruno Olsen
    Hi again
    Got it working :)
         <rewrite>
            <rules>
                <rule name="JobRewrite">
                    <match url="^test/([0-9]+)" />
                    <action type="Rewrite" url="test/?age={R:1}" />
                </rule>
            </rules>
         </rewrite>
    in the system.webServer segment of web.config :)
    Kind regard, Bruno
