Update hits this action from another url named "/rediger-turmaal" and works as it should:
[HttpPost]
[NotChildAction]
// Submit button: Partial Views UpdateHikingDestination.cshtml
public ActionResult UpdateHikingDestination(HikingDestinationViewModel model)
// Object reference not set to an instance of an object.
try
if (Members.IsLoggedIn() && Members.IsMemberAuthorized(allowTypes: new[] { "hiker" }))
// Servervalidate fields
if (model.StartDate.ToString().Length < 1) { ModelState.AddModelError("", "Angi startdato for turmål"); }
if (!ModelState.IsValid)
return CurrentUmbracoPage();
//nodeId same value as nodeId in db table cmsMember
model.nodeId = Members.GetCurrentMemberId();
model.SelectedHikingDestination = model.SelectedHikingDestination;
model.Title = model.Title;
model.StartDate = model.StartDate;
model.HikingCode = model.HikingCode;
//Get the Umbraco db
var db = ApplicationContext.DatabaseContext.Database;
//Update the object to the DB
db.Update(model, model.Id);
//All done - redirect to the page
ModelState.Clear();
return Redirect("/turmaal");
TempData["updateSuccess"] = true;
catch (NullReferenceException ex)
// Maybe also servervalidate?
ModelState.Clear();
But don't know why exactly this action was executed, and how model and model.Id was found.
Delete hit this action now, and it's no surprice (and it works):
[HttpGet]
public ActionResult DeleteHikingDestination(int Id, int redirectId)
try
HikingDestinations.DeleteById(Id);
TempData["deleteSuccess"] = true;
return RedirectToUmbracoPage(redirectId);
ModelState.Clear();
But how can I specify the link to use this action instead (similar to UpdateHikingDestination that works)?
[HttpPost]
[NotChildAction]
public ActionResult DeleteHikingDestination(HikingDestinationViewModel model)
try
//Delete the DB-object
db.Delete(model.Id);
ModelState.Clear();
ModelState.Clear();
How to send a model from view to controller? With Id I find correct action, but not with model.
Can I use @Url.SurfaceAction for both change and delete buttons/links?
I have tried these two, but didn't make them work (how should they be written?):
public static string SurfaceAction(this UrlHelper url, string action, string controllerName, object additionalRouteVals);
public static string SurfaceAction<T>(this UrlHelper url, string action, object additionalRouteVals) where T : SurfaceController;
I need to get more control of which action is being taken, also because I need to extend the controller with another delete action to confirm that members really want to delete the item before deleting.
Then I got this message:
"The parameters dictionary contains a null entry for parameter 'Id' of non-nullable type 'System.Int32' for method 'System.Web.Mvc.ActionResult DeleteHikingDestination(Int32, Int32)' in 'Neoweb.Controllers.HikingDestinationSurfaceController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
Parameter name: parameters"
So it looks like it hits the same Action as before (I wrote { model = Model }, but that's maybe wrong)?
Passing model from view to surfacecontroller
Partial view inside of @using (Html.BeginUmbracoForm
modelandmodel.Idwas found.Delete hit this action now, and it's no surprice (and it works):
Hi Tom,
just wild guessing to be honest but if this works:
have you tried using:
maybe that works too?
Regards David
Hi David.
Then I got this message: "The parameters dictionary contains a null entry for parameter 'Id' of non-nullable type 'System.Int32' for method 'System.Web.Mvc.ActionResult DeleteHikingDestination(Int32, Int32)' in 'Neoweb.Controllers.HikingDestinationSurfaceController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter. Parameter name: parameters"
