UmbracoVirtualNodeByIdRouteHandler - How to get the node by Guid (Custom Routing)
Hi Guys,
Here is a bit of an issue I can trying to figure out.
I started using Umbraco Courier 3 and it works great.
I noticed when Courier uploads nodes/documents to the live environment the Id is different but it retains the same Guid. Fine! I expected this would be the case.
Because of this I have started referencing nodes by Guid rather than the Id since there wont be any confusion on local, staging, and live when referencing nodes.
This has been working fine for everything except this one issue.
Part of my application has custom routes within the application starting event.
E.g
RouteTable.Routes.MapUmbracoRoute(
"JobSearch1",
"find-a-job/search-jobs/{value1}",
new
controller = "Routing",
action = "JobList"
new UmbracoVirtualNodeByIdRouteHandler(1276));//job list page Id
Obviously as per my description above I no longer want to use Ids as the primary referencing. So this line of code becomes an issue.
I couldn't find an equivilant that accepts a Guid. First of all if anyone knows an equivilant then please shout out.
I attempted to get around this by the following code
var umbracoHelper = new Umbraco.Web.UmbracoHelper(Umbraco.Web.UmbracoContext.Current);
int Id = umbracoHelper.TypedContent(guid).Id;
"JobSearch1",
new
action = "JobList"
new UmbracoVirtualNodeByIdRouteHandler(Id));//job list page Id
The issue here is that in the starting event the context doesn't exist. I have using the EnforceUmbracoContext in the past with similar issues but in this case its not working and I am really not confidant this is the way to go. Its too much of an hack and I am guessing it's going to cause all sorts of problems at a later date.
So I have figured out a way around this. I am not sure if this the best way so I am keen to hear what other people are doing.
I use the same code for the custom route. The only difference is instead of using the Id of the page this will route to for the virtual node I simply use the Id of the homepage. This will always be the same between staging and live. Plus its not that important as long as its an Id that exists.
"JobSearch1",
new
action = "JobList"
new UmbracoVirtualNodeByIdRouteHandler(1063));//Homepage Node Id
The next part of this hack is within the controller handing the return of the model. I simply created a new RenderModel based on the Guid I wanted to use then passed this back out instead of the virtual node as I was previously using.
public class RoutingController : Umbraco.Web.Mvc.RenderMvcController
public ActionResult JobList(RenderModel model)
model = new RenderModel(BusinessManager.GetPublishedContentByGuid(Guid.Parse("a25dbd15-f4fb-4fc5-9b4d-23c40fd2e115")));
return View("JobList", model);
I hope this helps someone. If anyone knows of a better solution please let me know.
You should never reference to a hardcoded node. Rather create your own virtual route handler.
public class FindJobPageRouteHandler : UmbracoVirtualNodeRouteHandler
protected override IPublishedContent FindContent(RequestContext requestContext, UmbracoContext umbracoContext)
// change this to whatever you need, but make sure it is fast!
var jobspage = umbracoContext.ContentCache.GetAtRoot().First().FirstChild<MyJobAreaDocType>();
return jobspage ;
Then replace your new UmbracoVirtualNodeByIdRouteHandler(1063) with new FindJobPageRouteHandler() when adding your route.
Like this you won't need the context to route to the correct page.
Hope this helps
Kind regards
Damiaan
PS: I won't mark your own reply as an accepted solution, if you want other people to jump in. Btw, it is only a workaround, not a solution. :-p
I have the same setup running on Umbraco 7. But i've started to migrate to Umbraco 13. How would that setup then work. It doesnt seem like there's a way to pass the node id from the MapControllerRoute in my program.cs?
Hi Guys,
E.g
https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/57892-IPublishedContent-and-GatheringNodeData
Cant anyone point me in the right direction or give me some advise on this?
Thanks in advance.
Kind Regards
David
Kind Regards
David
Hi David,
Then replace your
new UmbracoVirtualNodeByIdRouteHandler(1063)withnew FindJobPageRouteHandler()when adding your route.Like this you won't need the context to route to the correct page.
Hope this helps
Kind regards
Damiaan
I can confirm I was also able to implement this solution as described. Thanks for you help. Much appreciated :)
Any insight would be appreciated :)
