Fetching SQL alias from custom tables in Umbraco database
The SQL statement works as it should in SQL Server Management Studio - displays all the values from alias and all fields.
But how do we extract the value of SQL aliasNumberOfHikingDestinations into the model?
The field I want values from is retrieved with: COUNT(Id) AS NumberOfHikingDestinations below.
public static IList<HikingDestinationViewModel> GetHikingDestinationGroupedByMember(int NodeId)
UmbracoDatabase db = Umbraco.Core.ApplicationContext.Current.DatabaseContext.Database;
return db.Fetch<HikingDestinationViewModel>(
"SELECT DISTINCT COUNT(Id) AS NumberOfHikingDestinations, nodeId, SelectedHikingDestination, HikingCode " +
"FROM [HikingDestinations] WHERE DATEPART(yyyy, StartDate) >= DATEPART(yyyy, GETDATE()) AND SelectedHikingDestination = @0 " +
"GROUP BY SelectedHikingDestination, nodeId, HikingCode ORDER BY NumberOfHikingDestinations DESC", NodeId);
These are parts of the model HikingDestinationViewModel I use:
public int nodeId {get; set; }
public int? SelectedHikingDestination {get; set; }
public DateTime StartDate {get; set; }
public string HikingCode {get; set; }
which refers to the values in a custom database table [HikingDestinations]:
and in the surface controller the sql results is looped and the values can be obtained in this foreach loop:
IEnumerable<HikingDestinationViewModel> allHikingDestinationsGroupedByMember = HikingDestinations.GetHikingDestinationGroupedByMember(Node.getCurrentNodeId());
foreach (HikingDestinationViewModel hikingDestination in allHikingDestinationsGroupedByMember)
//Codes to fetch the values from the databasetable [HikingDestinations] goes here..
//Values OK (not empty) from nodeId, SelectedHikingDestination, HikingCode
//Values EMPTY in hikingDestination.NumberOfHikingDestinations
If I put this in model HikingDestinationViewModel:
public int NumberOfHikingDestinations { get; set; } << NOTE: I've tried int? and int
and I try to retrieve hikingDestination.NumberOfHikingDestinations in the loop of the surface controller, the content is empty.
So how are we doing this, fetching data from SQL aliasNumberOfHikingDestinations?
The solution: Add [Column("NumberOfHikingDestinations")] to HikingDestinationViewModel, and the SQL alias COUNT(Id) AS NumberOfHikingDestinations are now defined with values in the foreach loop:
[Column("nodeId")]
public int nodeId { get; set; }
[Column("SelectedHikingDestination")]
public int? SelectedHikingDestination { get; set; }
[Column("StartDate")]
public DateTime StartDate { get; set; }
[Column("HikingCode")]
public string HikingCode { get; set; }
[Ignore] // Column not created in the custom Umbraco database table
Now the class in my repository can run the SQL string with all defined columns from HikingDestinationViewModel
Then looping all the values from the repository in the surfacecontroller,:
//Codes to fetch the values from the custom db table [HikingDestinations], defined in HikingDestinationViewModel goes here..
Then the result was send to the partial view, and the calculations now works (showing numbers other than 0).
But of course, always something that is not going to work. I get the same errormessage with insert and update.
The error message come if I use [Ignore]
in my viewmodel HikingDestinationViewModel instead of
That is, in order not to get an error message, I have to create an empty column named NumberOfHikingDestinations in custom database table [HikingDestinations] (or not use [Ignore] in my viewmodel).
This is not quite optimal, so someone who knows how to avoid having to create an empty column?
NumberOfHikingDestinationsinto the model?The field I want values from is retrieved with:
COUNT(Id) AS NumberOfHikingDestinationsbelow.These are parts of the model
HikingDestinationViewModelI use:which refers to the values in a custom database table [HikingDestinations]:
HikingDestinationViewModel:and I try to retrieve
hikingDestination.NumberOfHikingDestinationsin the loop of the surface controller, the content is empty.So how are we doing this, fetching data from SQL alias
NumberOfHikingDestinations?The solution: Add
[Column("NumberOfHikingDestinations")]toHikingDestinationViewModel, and the SQL aliasCOUNT(Id) AS NumberOfHikingDestinationsare now defined with values in the foreach loop:Now the class in my repository can run the SQL string with all defined columns from
HikingDestinationViewModelThen looping all the values from the repository in the surfacecontroller,:
[Ignore]in my viewmodel
HikingDestinationViewModelinstead ofThat is, in order not to get an error message, I have to create an empty column named
NumberOfHikingDestinationsin custom database table[HikingDestinations](or not use[Ignore]in my viewmodel).This is not quite optimal, so someone who knows how to avoid having to create an empty column?
