  • nickornotto 403 posts 907 karma points
    Sep 13, 2017 @ 09:05
    nickornotto
    Trouble of url mapping in route hijacking in EventHandler
    I am trying to hijack route in EventHandler. I don't know how to map the first part of the url which is currently this:
    "the-top-parent/parent/library/{id}/{slug}"
    and it works without problem.
    What I would like to do instead of the above is to have:
    "{parentslug}/library/{id}/{slug}"
    but that doesn't work - the app cannot find the template if the first bit of the url is dynamic/ not predefined - and displays error instead of the valid page:
    Sequence contains no elements
    Is it possible to make the start of the url optional? And how?
    public ActionResult GetItem(RenderModel renderModel, string parentslug, int? id, string slug) {
    public class MyStartupHandler : IApplicationEventHandler
        public void OnApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            RouteTable.Routes.MapRoute(
                "item",
                "the-top-parent/parent/library/{id}/{slug}",
                new
                    controller = "MyController",
                    action = "GetItem",
                    slug = UrlParameter.Optional
    I'm using Umbraco 7.1.8.
  • Damiaan 442 posts 1302 karma points MVP 6x c-trib
    Sep 13, 2017 @ 09:08
    Damiaan
    You could create a contentfinder.
    Especially the example on the linked page above:
    public class MyContentFinder : IContentFinder
      public bool TryFindContent(PublishedContentRequest request)
        var path = request.Uri.GetAbsolutePathDecoded();
        if (!path.StartsWith("/woot"))
          return false; // not found
        // have we got a node with ID 1234?
        var contentCache = UmbracoContext.Current.ContentCache;
        var content = contentCache.GetById(1234);
        if (content == null) return false; // not found
        // render that node
        request.PublishedContent = content;
        return true;
    Hope that helps.
    Sep 13, 2017 @ 10:26
    nickornotto
    Thanks but I read the article you quoted and am not sure how to implement it so I can route correctly what I need?
    Sep 13, 2017 @ 11:59
    Damiaan
    Ok. Fair question. Let's turn things around. Why do you want to route to a controller? Is their a umbraco node matching the url?
    Sep 13, 2017 @ 15:07
    nickornotto
    To keep consistent with the page parent structure
  • Marcio Goularte 388 posts 1361 karma points
    Sep 13, 2017 @ 17:44
    Sep 14, 2017 @ 08:07
    nickornotto
    Thanks Marcio but I'm not having problem with routing - it works fine.
    I want to make the start of url in MapRoute optional and this is what I don't know how to achieve.
    Eg. instead of
    I want to use
    "{parentslug}/parent/library/{id}/{slug}"
    and pass parentslug as parameter as well to the handling method.
