  • Kieron McIntyre 117 posts 360 karma points
    Sep 18, 2017 @ 21:09
    Kieron McIntyre
    "Unknown provider: n from umbraco" issue
    Locally and on staging (Azure App Service) my Umbraco v7.6.5 site is working fine but in production (also Azure App Service) I cannot log into Umbraco as the login screen is blank and I get the following error:
    Given that the sites work in two of the the three configurations, I assume it is a configuration issue but I've compare all the configuration files and they are fine. Also the Azure configuration seems fine too - both staging and production sites run as expected.
    What would cause this error? Is this a Web API failing somewhere? Any help would be much appreciated.
  • Craig Mayers 164 posts 508 karma points
    Sep 18, 2017 @ 23:13
    Craig Mayers
    Hi Kieron,
    Have you copied the App_Data folder for this site from one of the other sites?
    If so, can you try deleting the TEMP folder in App_Data Then recycle the AppService in Azure and try again.
    Let me know how it goes.
    Craig
    Sep 22, 2017 @ 13:16
    Kieron McIntyre
    No luck there I'm afraid, I've redeployed the site entirely, App_Data and all and there's no change. I set debugging to true and got the following which still isn't much help:
    Obviously something to with Angular not recognising something but I have no idea what. Anyone any ideas?
    Sep 22, 2017 @ 13:40
    Craig Mayers
    Hi Kieron,
    Do you have any custom datatypes OR sections?
    Also, have you done a diff on your local (to compare with the problematic site)? Maybe something has not been uploaded... I tend to use BeyondComapre OR WinMerge for diffs
    Craig
    Sep 22, 2017 @ 14:01
    Kieron McIntyre
    Yes to the datatypes but I would have expected these to have caused the same issue locally and on staging.
    I have actually used WinMerge on all the config files which would have transforms applied to them and they're all as expected.
    I have just deployed the site to a new Azure app service instance and that is working fine. I haven't applied a custom domain on to it yet, so that may be the issue but I'll update here as I get news.
    Oct 03, 2017 @ 08:08
    Kieron McIntyre
    Still no idea what caused this but created a new Azure app service and redeployed to this and everything worked fine.
    So the configuration was presumably ok but maybe a rogue file was present or maybe something missing.
